John Mac
更新時間 2019-04-22 23:42:30 UTC
瀏覽: 4558   回覆: 1
Nathan Anderson
更新時間 2019-02-13 03:53:31 UTC
瀏覽: 5087   回覆: 1
Tim Cox
更新時間 2019-02-02 01:35:59 UTC
瀏覽: 5127   回覆: 3
Sangjin Lee
更新時間 2018-12-15 18:56:48 UTC
Thanks in advance!
瀏覽: 8092   回覆: 1
Water pump shutting off
Ryan Cochran
更新時間 2018-11-26 02:32:24 UTC
瀏覽: 5081   回覆: 1
Controller
Phil Samson
更新時間 2018-10-12 18:41:33 UTC
My controller shows that it’s online but the app is saying I’m offline. How do I correct this?
瀏覽: 4737   回覆: 0
Sprite not running zones after power outage
Rob Platko
更新時間 2018-09-08 17:28:57 UTC
Hi, my Sprite does not run any program on any zone following a power outage.  The zones are scheduled, I can see them in the calendar, but they don’t run.  Anyone seen this problem?
瀏覽: 4775   回覆: 0
