Scott Gustafson
更新時間 2022-04-14 22:26:18 UTC
瀏覽: 2929   回覆: 1
idpitt
更新時間 2022-04-03 14:58:04 UTC
瀏覽: 3004   回覆: 1
metellusa@gmail.com
更新時間 2022-03-21 18:45:44 UTC
瀏覽: 2836   回覆: 1
Netro pixie in standby
mbhi
更新時間 2022-03-12 10:44:15 UTC
瀏覽: 2680   回覆: 1
Gabriele Cofano
更新時間 2022-03-02 12:45:59 UTC
瀏覽: 2678   回覆: 1
Interface
John Degolyer
更新時間 2022-03-02 05:58:45 UTC
瀏覽: 3097   回覆: 2
Duane Smith
更新時間 2022-02-16 21:58:22 UTC
Good Afternoon Everyone,
Duane
瀏覽: 2709   回覆: 1
whisperer off almost 1 month
更新時間 2022-02-16 17:01:49 UTC
seems that whisperer didnt collect data for almost one month!!, this is due to battery? we are in winter but it’s installed on a sunny place!! and app did no send alerts when this happens!!?
瀏覽: 3070   回覆: 1
Pixie smart timer battery not charging
Becky Aquino
更新時間 2022-01-23 00:57:20 UTC
Anyone have an issue with the pixie battery not charging from the unit using solar? My battery level is down to 19% and I live in Hawaii, lots of sun. Not sure if I did something wrong.
瀏覽: 2664   回覆: 1
Sensor sending wrong data
Mick Faulks
更新時間 2022-01-14 06:49:41 UTC
Hi have my whisperer installed in a garden bed, it saying 0% moisture when the soil is quite wet and it is saying temp is 200 C up to 380 C I have reset it many times but continues to give these readings.
瀏覽: 2934   回覆: 1
i have problem with netro sprite 6
Nguyễn Vinh
更新時間 2022-01-06 04:51:41 UTC
I am a distributor of netro products in Vietnam market
My customer just sent back a product with a burnt electronic device inside (pictured). can you tell me what the possible reason is and how to fix it.
- 220V (stable) power supply
- no lightning or explosion
- Full safety equipment to protect electrical equipment when there is a problem.
Thank you very much
瀏覽: 2879   回覆: 1
No restrictions set, yet program is skipping because of user restrictions
alan.ashby
更新時間 2022-01-02 11:40:53 UTC
I have no restrictions set, yet the app is indicating that restrictions are set and scheduled days are being skipped when they should not be.  Please see app screen shots.
瀏覽: 2554   回覆: 1
2 programs scheduled on one day
paul hewitt
更新時間 2021-12-24 05:21:45 UTC
I added an afternoon program after the morning one had run to run daily as very hot over next few days. After setting it up I went into schedule to make sure it was there and all that appears on the day is the morning schedule with a yellow triangle with exclamation mark instead of the usual tick to say it was done. I did see it running the morning schedule.
Why doesn't the afternoon schedule show up as well as the morning one?
Paul
瀏覽: 2852   回覆: 1
Lyndon Whyatt
更新時間 2021-12-22 19:53:57 UTC
I reset my Whisperer sensor by following the reset instructions and on restart it flashed white. I added the sensor via the app but it didn’t produce a WiFi signal and I couldn’t connect to it in Settings on my iPhone. After a while it flashes dark blue.
What is happening and how can I fix it?
瀏覽: 3023   回覆: 1
davejburton@gmail.com
更新時間 2021-12-16 01:35:31 UTC
Howdy!
瀏覽: 2731   回覆: 1
I have problem with netro pixie
Nguyễn Vinh
更新時間 2021-12-01 06:33:51 UTC
My Pixie can't enable manual mode, when i manually launch the app it says "Pending" and it doesn't work
瀏覽: 2833   回覆: 1
Whisperer temperature and moisture readings are way off
Andrew
更新時間 2021-11-28 00:35:49 UTC
I recently bought a whisperer and for the first few days it worked perfectly but now it consistently reports the temperature as being over 300 degrees celcius, and soil moisture at 0% even while it has been raining here for a week.
I've tried relocating the whisperer and deleting and re-setting it up twice but get the same result.
I'm unsure what else to try. Does anyone have advice or a fix for issues like this?
瀏覽: 3502   回覆: 2
Roger Prunonosa Duran
更新時間 2021-11-22 10:30:32 UTC
They haven’t lasted much…
瀏覽: 3382   回覆: 2
Yellow triangle error
James Mershon
更新時間 2021-10-06 12:23:33 UTC
瀏覽: 2765   回覆: 1
更新時間 2021-10-03 16:59:12 UTC
瀏覽: 3159   回覆: 1
