Sprinklers run repeatedly
Sunil Sivanand
更新時間 2022-08-12 01:18:11 UTC
瀏覽: 2705   回覆: 1
Juan Brea
更新時間 2022-07-26 18:08:13 UTC
瀏覽: 2726   回覆: 1
Repuesto
Juan Pascual
更新時間 2022-07-23 08:12:17 UTC
Buenos días desde España
Mil gracias
瀏覽: 3043   回覆: 2
Zone won't shut off
chesh235
更新時間 2022-07-18 18:53:38 UTC
瀏覽: 2854   回覆: 2
Plant sensor
Miro D
更新時間 2022-07-14 10:42:35 UTC
瀏覽: 2688   回覆: 1
More data
Jim Shaffer
更新時間 2022-07-13 13:06:30 UTC
瀏覽: 2710   回覆: 1
Android devices logout issue
Wency Pan
更新時間 2022-07-12 06:35:45 UTC
瀏覽: 4241   評論: 1
Pump Problem
wvfox
更新時間 2022-06-28 16:18:58 UTC
Vance
瀏覽: 2688   回覆: 1
New Whisperer Issue
Alfonso Marin Salgueiro
更新時間 2022-06-24 15:15:07 UTC
Hello everyone from Spain.
Can somebody help me?
I attach a photo.
Thank you very much.
瀏覽: 2819   回覆: 1
更新時間 2022-06-19 17:14:35 UTC
Added information:
瀏覽: 3702   回覆: 4
end Battery life?
更新時間 2022-06-15 13:23:27 UTC
瀏覽: 2803   回覆: 1
Tech support
Robert Dambrosio
更新時間 2022-06-13 00:41:59 UTC
瀏覽: 3088   回覆: 1
Netro light
beppezhome
更新時間 2022-06-09 14:46:24 UTC
瀏覽: 2697   回覆: 1
James Berg
更新時間 2022-06-05 01:03:46 UTC
瀏覽: 3330   回覆: 1
Andy Ricco
更新時間 2022-05-31 06:12:27 UTC
瀏覽: 2974   回覆: 1
Sleeping mode
Fabrice GOUFFRAN
更新時間 2022-05-18 10:11:40 UTC
瀏覽: 4257   評論: 1
water valve does not work
Paolo Raviolo
更新時間 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
瀏覽: 2639   回覆: 1
Pixie shows "communicating" and timer counting down but valve not open?
Douglas Ely
更新時間 2022-05-01 15:54:22 UTC
When trying to use the Pixie to manually water the garden, I go to the Netro app and select the pixie. It shows "sleeping", 99%charged. I then select "manual run" and set a time. The app then grays out and says "communicating" as the timer begins counting down my preset manual time but the valve stays closed. Why? When does it open?
瀏覽: 3267   回覆: 3
Location outside USA
Eduardo Prieto
更新時間 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
瀏覽: 2583   回覆: 1
Incorrect rainfall accumulation
rwflower
更新時間 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
瀏覽: 2909   回覆: 2
