JanT
更新時間 2020-07-08 18:44:04 UTC
瀏覽: 3169   回覆: 1
Jim Falvey
更新時間 2020-07-07 23:54:23 UTC
瀏覽: 3369   回覆: 1
low water pressure
vic sabo
更新時間 2020-07-02 22:08:39 UTC
瀏覽: 3274   回覆: 1
Power Cycle
Jorge Bastos
更新時間 2020-06-26 22:30:53 UTC
Any way to correct this?
Regards.
瀏覽: 3186   回覆: 1
Mark Poppen
更新時間 2020-06-12 01:34:57 UTC
瀏覽: 3428   回覆: 1
Watering program
Maciej Karpinski
更新時間 2020-05-18 01:01:57 UTC
瀏覽: 3441   回覆: 1
alnavasa
更新時間 2020-05-08 20:36:44 UTC
Start ar 21:00 end at 3am
瀏覽: 3958   評論: 0
I want to increase watering time since it only says 2:00 minutes (it works for this time) but am unable to increase/change it. Please help. Please help!
Anne Knudsen
更新時間 2020-05-03 16:47:04 UTC
I can not change the time (number of minutes) for watering to happen. please help.
Two of the zones are 45 minutes and 60 minutes and they work.
瀏覽: 3196   回覆: 1
Watering when zones are off
Ben Wojcik
更新時間 2020-05-02 13:07:30 UTC
I turned off all my zones, but my netro still stays is watering.  How do I get it to stop doing this?  I can't figure out what its watering either.
瀏覽: 3888   回覆: 1
Problem with controling relay
Srdjan
更新時間 2020-04-26 06:54:18 UTC
Hi, i try to control working water pump by M contact on controler using relay(24VAC) and that is not posible, I try with three different relays and same situation.
Is anybody have same or similary problem and if anybody use M contact for controling relay please send tehnical data or picture of that releay that I can buy same... Suporrt not answering on this question I send them video of working two different relays but not got answer...
I tru to upload video here but that is not posible...
Thank for help.
瀏覽: 3294   回覆: 1
Pixie Leaks
Rich Keith
更新時間 2020-04-19 17:18:48 UTC
瀏覽: 3279   回覆: 1
Max V
更新時間 2020-04-17 09:46:19 UTC
瀏覽: 3404   回覆: 1
Luca Manfrin
更新時間 2020-04-10 11:43:03 UTC
瀏覽: 3743   回覆: 2
Seb Cruzer
更新時間 2020-04-07 15:03:43 UTC
hello,
Please help!
瀏覽: 3557   回覆: 2
Luca Manfrin
更新時間 2020-04-07 09:33:03 UTC
瀏覽: 3297   回覆: 1
Host mode
Luca Manfrin
更新時間 2020-04-06 17:55:38 UTC
What is host mode?
瀏覽: 3530   回覆: 1
Casey S
更新時間 2020-04-05 19:41:30 UTC
瀏覽: 3522   回覆: 1
Yohan
更新時間 2020-03-22 00:49:00 UTC
瀏覽: 3346   回覆: 1
stefano banfi gaslini
更新時間 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
瀏覽: 3303   回覆: 1
Whisperer issue
Saul Perez
更新時間 2020-03-15 19:07:50 UTC
瀏覽: 3272   回覆: 1
