One channel is always on
Stefan W.
更新時間 2023-05-27 19:58:05 UTC
Hi everyone,
I have a 6-channel Sprite with 6 hunter valves. 5 channels work perfectly, one seems to be always on. I tried a brand new valve, a reset of the Sprite, unplugged it from power, changed the wiring but nothing helped. Any ideas?
Cheers, Stefan
瀏覽: 2475   回覆: 3
Zones
Lea Schneider
更新時間 2023-05-25 23:29:01 UTC
My zones 5-12 won’t work but my zones 1-4 are working fine .    Any ideas what to do ?
瀏覽: 2383   回覆: 1
Watering problem
Marco Nicosia
更新時間 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
瀏覽: 2260   回覆: 1
更新時間 2023-05-14 12:23:35 UTC
Kirk
瀏覽: 2582   回覆: 1
No light
Gabriele Gualtieri
更新時間 2023-05-10 17:13:50 UTC
瀏覽: 2468   回覆: 1
Katie Woggins
更新時間 2023-04-24 18:40:07 UTC
瀏覽: 2308   回覆: 1
Master error “open circuit”
Neil Lucey
更新時間 2023-04-24 14:09:12 UTC
Neil
瀏覽: 2344   回覆: 1
Pixie keeps disconnecting
Sang Peiris
更新時間 2023-04-18 12:44:42 UTC
瀏覽: 2445   回覆: 1
No 24V output?
Bigolin Davide
更新時間 2023-03-26 16:15:24 UTC
What can I do?
瀏覽: 2309   回覆: 1
Carlo Drago
更新時間 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
瀏覽: 2557   回覆: 1
Smart schedules
Vincent Coutinho
更新時間 2023-02-07 20:51:01 UTC
瀏覽: 2546   回覆: 1
API
更新時間 2022-11-18 11:22:08 UTC
瀏覽: 2718   回覆: 1
Gianluca Bus
更新時間 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
瀏覽: 2597   回覆: 1
Water valve opened
Paolo Talamelli
更新時間 2022-10-23 10:52:29 UTC
瀏覽: 2516   回覆: 1
Sprite-6
Rockhead413
更新時間 2022-09-26 18:04:30 UTC
Vincent Devlahovich
瀏覽: 2788   回覆: 1
Watering during a restriction
Valeria Dp
更新時間 2022-09-20 20:26:21 UTC
Tonight at 2.30 my netro start to watering. I had to stop it starting a manual program and stop it because in the app there was no watering sign.
Then I put a restriction for 3 days and around noon netro starts to watering again. There was a lost wifi signal for a minute cause by a voltage drop.
Is it normal?
瀏覽: 2776   回覆: 1
Cannot reset Sprite
punyelroo
更新時間 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
瀏覽: 2906   回覆: 1
Karen Thompson
更新時間 2022-09-02 15:15:20 UTC
瀏覽: 2997   回覆: 1
A Gallo
更新時間 2022-08-29 14:28:38 UTC
瀏覽: 2820   回覆: 1
Clock on sprite
Rory
更新時間 2022-08-24 19:43:30 UTC
瀏覽: 2571   回覆: 1
