更新時間 2019-07-01 16:32:17 UTC
瀏覽: 3935   回覆: 1
internet may not be available
Bruce Vermeulen
更新時間 2019-06-30 18:31:02 UTC
Bruce
瀏覽: 3565   回覆: 0
WiFi connection
Andrew
更新時間 2019-06-27 00:49:26 UTC
瀏覽: 3366   回覆: 0
Remove whisperer
Dan Orms
更新時間 2019-06-25 16:17:24 UTC
瀏覽: 3897   回覆: 1
Disconnecting Constantly
Kate Whelan
更新時間 2019-06-09 18:05:15 UTC
My Netro Smart Sprinkler Controller, WiFi, Weather aware, Remote access, 6 Zone, Compatible with Alexa disconnects CONSTANTLY from the app/network and I’m about to put back on our old school controller. Today it disconnected IN THE MIDDLE of watering the lawn while I was feeding/putting my baby down for a nap and it ended up watering for 28 mins, flooding my backyard. Ugh.
Any tips on fixing this? I do not have intermittent internet or power issues. Is there a hardware update? Aside from this, I LOVE it - but this is kind of a deal killer for me. I plan to call customer service on Monday, but thought I’d check here for tips to see if I can fix it sooner.
瀏覽: 4239   回覆: 1
Not watering on any zone
A Miller
更新時間 2019-06-02 18:39:10 UTC
The sprite worked perfect for about 3 weeks. Went out of town for a week, during that time it snowed for the entire duration of my trip. The unit worked as it should and didnt water. However when it should have picked up its schedule after weather cleared it did not. It will not run its zone at all. I have checked the resistance on all zones solenoids and they are fine at 28 ohm. I reconnected my old hunter system and all zones worked properly with that controller. So whats the next step?
瀏覽: 6682   回覆: 1
Constant Blinking
Seth McDonald
更新時間 2019-05-31 00:32:04 UTC
My device appears to be connected and working, but I noticed the light on the unit is blinking constantly.  Is it supposed to be doing that?
瀏覽: 3719   回覆: 1
Don’t Stop !!
Eduardo Ariste
更新時間 2019-05-26 11:27:42 UTC
瀏覽: 3518   回覆: 1
jpmeyer81
更新時間 2019-05-19 15:04:11 UTC
瀏覽: 3927   回覆: 1
Roianne Cox
更新時間 2019-05-19 13:52:50 UTC
瀏覽: 3515   回覆: 1
Dennis N
更新時間 2019-05-18 17:52:30 UTC
瀏覽: 3585   回覆: 1
David Claridge
更新時間 2019-05-18 13:21:53 UTC
瀏覽: 3616   回覆: 1
John Locke
更新時間 2019-05-05 14:16:12 UTC
瀏覽: 3781   回覆: 1
John Mac
更新時間 2019-04-22 23:42:30 UTC
瀏覽: 3531   回覆: 1
Nathan Anderson
更新時間 2019-02-13 03:53:31 UTC
瀏覽: 4030   回覆: 1
Tim Cox
更新時間 2019-02-02 01:35:59 UTC
瀏覽: 4078   回覆: 3
Sangjin Lee
更新時間 2018-12-15 18:56:48 UTC
Thanks in advance!
瀏覽: 6637   回覆: 1
Water pump shutting off
Ryan Cochran
更新時間 2018-11-26 02:32:24 UTC
瀏覽: 4023   回覆: 1
Controller
Phil Samson
更新時間 2018-10-12 18:41:33 UTC
My controller shows that it’s online but the app is saying I’m offline. How do I correct this?
瀏覽: 3708   回覆: 0
Sprite not running zones after power outage
Rob Platko
更新時間 2018-09-08 17:28:57 UTC
Hi, my Sprite does not run any program on any zone following a power outage.  The zones are scheduled, I can see them in the calendar, but they don’t run.  Anyone seen this problem?
瀏覽: 3746   回覆: 0
