Whisperer shows different data on hourly vs daily humidity
Panos Charalambopoulos
更新時間 2021-05-03 07:40:53 UTC
My whisperer shows 99% humidity stuck in one zone in the hourly and dashboard views. The weekly daily monthly views all show progressively dropping humidity. Which one is correct and how do I possibly reset this ? Also do my watering schedules get affected by the hourly or the daily humidity ?  My other whisperer shows consistent data between hourly and other views.
瀏覽: 2825   回覆: 1
Whisper controlled zone down to 11%
Simon Clark
更新時間 2021-04-28 20:59:55 UTC
I have a whisper connected to a zone that I have defined as new plant as it’s young vegetable plants. It says it will run every day for 9 minutes.
However it’s not come on for the last week and when I checked today the moisture was down to 11%!
Why hasn’t the zone been running?
I can’t rely on your product if it doesn’t do the basics that keeps my plants alive.
瀏覽: 3134   回覆: 1
Weather data
Vardhan Rajkumar
更新時間 2021-04-21 18:03:34 UTC
Vardhan
瀏覽: 3174   回覆: 1
Michael Sheahan
更新時間 2021-04-19 21:19:54 UTC
瀏覽: 2884   回覆: 1
Tony Pellegrino
更新時間 2021-04-13 19:14:36 UTC
瀏覽: 2906   回覆: 1
jjmengibar
更新時間 2021-04-05 18:19:11 UTC
瀏覽: 3158   回覆: 1
Many inexplicable Manual runs
更新時間 2021-04-03 11:37:15 UTC
Hello everyone ,
瀏覽: 2953   回覆: 1
Wild Swings In Moisture %
Mike Biondo
更新時間 2021-03-27 22:08:54 UTC
I am seeing 20%+ increases in soil moisture when there is no rain and I am not watering and also 20%+ reductions in moisture directly after watering which seems counterintuitive. Is this normal? Can anyone explain what is going on to me? Thank you!
Mike
瀏覽: 3114   回覆: 1
AMC
更新時間 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
瀏覽: 3030   回覆: 2
Master valve timing
joeac
更新時間 2020-12-04 05:38:31 UTC
Product: Sprite
Joe
瀏覽: 3119   回覆: 1
Email address length
Alberto Castro Hinojosa
更新時間 2020-10-24 21:37:57 UTC
Could you review please?
瀏覽: 3139   回覆: 1
HomeOwner
Isaac Fishman
更新時間 2020-09-21 01:14:55 UTC
瀏覽: 3041   回覆: 1
controller kept go offline
更新時間 2020-09-05 01:12:13 UTC
Hello, wondering why my watering controller kept going offline.  Once turning it off/on, it will goes online again but will go off in several hours later.  Is it time for me to get a new controller?  I hope not
瀏覽: 3590   回覆: 2
Battery not charging
Petar Nedyalkov
更新時間 2020-08-21 18:24:41 UTC
My solar powered controller doesn’t charge its battery - not sure if it’s a battery problem - the controller is under direct sunlight for at least 6 hours every day.
I’ve set it to water for 1 hour every day so it’s a simple On/Off once a day.
Have other people had this issue?
瀏覽: 3454   回覆: 2
Unable to reset into Host mode to change WiFi setting
dabo
更新時間 2020-08-16 17:29:54 UTC
I have a 6 zone Netro sprite and need to update my wifi settings. No matter what I do I'm unable to get the Netro to enter host mode. I've tried hitting the RST button numerous times before or after manual reboots (even waiting the full 3+ minutes after re-plugging the device in). I even tried a full manual reset by holding the RST button for 10 seconds and the device still doesn't reset. I'm starting to doubt whether the reset button on my device works.
Has any one had any similar problems or pointers for just getting the Netro to join a new WiFi network? I'd rather not do a full reset and lose my zone settings, but at this point I've even tried that and can't get that working.
瀏覽: 3375   回覆: 2
No funciona
Fre Camp
更新時間 2020-08-13 07:40:48 UTC
En la APP todo parece ir bien, pero no riega.
瀏覽: 3230   回覆: 2
Battery not holding charge
Steve Walczak
更新時間 2020-08-12 17:49:20 UTC
瀏覽: 3185   回覆: 2
Skipped watering on calendar and the system still watered...
Daniel Schoonover
更新時間 2020-07-26 01:36:47 UTC
I noticed system was going to water this afternoon so I skied the watering on the calendar hours before.
When the time came the system still watered my yard?
Why?
And I could not find a single way to stop it.
瀏覽: 3264   回覆: 1
Netro Sprite dead after 27 months (3 months post-warranty)
Doug Burkott
更新時間 2020-07-17 11:26:34 UTC
Has anyone had an issue with their Sprite being inoperable shortly after the warranty ended?  I tested the power prongs with a voltmeter and the controller is getting electricity, but no lights are on.   It's 105 deg in Austin and no rain in sight.  I'm going out of town for 5 days, so I'm in trouble.  I'm going to have to go to Home Depot to get something off the shelf installed today before my trip.
Anyone with the same problem?  Has anyone been successful with a claim outside of the warranty period?
Update:  The Sprite went offline at the same time the LED light stopped working.  The watering schedule resumed two days later and the LED was still off.  Meaning - Sprite works fine, LED doesn't work.  Netro told me to send the unit in over the winter and they will repair the LED.  Awesome - thanks Netro!
All the best,
-Doug
瀏覽: 3528   回覆: 2
Offline sratusc
Andrea Del Ben
更新時間 2020-07-12 19:31:12 UTC
瀏覽: 3306   回覆: 1
