Benedetto
更新時間 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
瀏覽: 3376   回覆: 1
Watering stops after 5 mins
D String
更新時間 2020-02-29 17:22:32 UTC
瀏覽: 3234   回覆: 1
Watering stop problem
lekter
更新時間 2020-02-14 14:43:36 UTC
When I start watering to give it a try. Everything's going well. But when I want to stop watering it's impossible. I have to turn off the power so that netro stops the watering.
WeatherPro is the problem ?
For information, I have an electrovanne rainbird.
Arnaud
瀏覽: 3403   回覆: 0
Light still blinking fast after pressing RST button
marcplesh
更新時間 2020-01-20 23:27:20 UTC
Any suggestions? Thanks. Already unplugged from outlet for about 10 seconds and plugged back in.
瀏覽: 3411   回覆: 1
setting up sprite location service on cellphone not on ... but it is
Michael Pakalolo
更新時間 2020-01-12 16:51:03 UTC
hi there, my sprite was working fine for 3 month , now i had no internet for 24 hours and sprite did not connect to the internet anymore . I restarted the router and then the sprite and still no internet connection but my router is fine and i have internet. So i reset the sprite and now it says i need to allow location service on my phone but it is on!!! it will not allow me to setup the sprite and i don't know what to do?
瀏覽: 3455   回覆: 1
Tim Foster
更新時間 2019-12-05 17:56:44 UTC
瀏覽: 3643   回覆: 1
Brian Hobbs
更新時間 2019-10-15 01:58:49 UTC
瀏覽: 3519   回覆: 1
Nguyễn Vinh
更新時間 2019-09-30 06:46:55 UTC
瀏覽: 3700   回覆: 2
更新時間 2019-09-17 12:12:15 UTC
瀏覽: 3776   回覆: 1
Power Transformer
DeanH
更新時間 2019-09-04 02:31:34 UTC
I have my controller in my garage here in the desert.  The transformer seems very hot to the touch.  Is this a problem??
瀏覽: 4642   回覆: 3
Yellow triangle with ! Inside
Michael Pakalolo
更新時間 2019-08-24 16:15:54 UTC
What does the yellow triangle with the ! mean next to the schedule
瀏覽: 3602   回覆: 1
Zones run at the same time
Rich Christenson
更新時間 2019-08-15 11:05:09 UTC
瀏覽: 3964   回覆: 3
Low pressure in zones
Hussein Diab
更新時間 2019-07-29 16:36:31 UTC
瀏覽: 3524   回覆: 1
Water stops running before the cycle is over
sgschrank
更新時間 2019-07-18 18:03:03 UTC
Recently I have been having issues with zones 5-8 stop watering before the cycle is over, but keeps counting down and moves to the next zone and does the same thing. I have tried resetting the unit, re-linking the wifi, but doesn't seem to make a difference. Help!
瀏覽: 3456   回覆: 0
更新時間 2019-07-12 15:05:29 UTC
瀏覽: 4085   回覆: 1
Rod Timby
更新時間 2019-07-11 18:14:39 UTC
瀏覽: 3472   回覆: 1
Rod Timby
更新時間 2019-07-11 18:09:47 UTC
瀏覽: 3369   回覆: 0
Whisperer Test
Dan Leng
更新時間 2019-07-10 18:29:27 UTC
瀏覽: 4083   回覆: 2
更新時間 2019-07-07 14:40:49 UTC
瀏覽: 4743   回覆: 1
Saurik
更新時間 2019-07-04 07:12:42 UTC
瀏覽: 3710   回覆: 1
