Whisperer 2 temperature?
Brett Rabe
更新時間 2025-05-09 19:07:46 UTC
Thoughts?
瀏覽: 187   回覆: 1
Andrea DS
更新時間 2025-04-22 12:33:21 UTC
瀏覽: 393   回覆: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
更新時間 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
瀏覽: 1053   回覆: 1
Sprite went offline
dkoford@gmail.com
更新時間 2024-12-18 02:30:29 UTC
瀏覽: 1267   回覆: 1
Solenoid does not switch off
Nath Moyes
更新時間 2024-11-15 00:49:20 UTC
Nath
瀏覽: 1392   回覆: 1
Netro Spark valve testing
Peter Strohmayer
更新時間 2024-11-14 13:49:20 UTC
Peter
瀏覽: 1313   回覆: 1
Zone won't shut off.
shoo.shoo
更新時間 2024-11-10 05:55:43 UTC
瀏覽: 1360   回覆: 1
BrettEnyart
更新時間 2024-10-13 18:02:06 UTC
瀏覽: 1525   回覆: 1
12330barryknoll
更新時間 2024-10-10 01:51:03 UTC
瀏覽: 1528   回覆: 1
cjulian
更新時間 2024-10-05 18:05:09 UTC
瀏覽: 1517   回覆: 1
Zone 1 not watering
11807GFT
更新時間 2024-09-24 23:25:59 UTC
瀏覽: 1658   回覆: 1
Thomas Murphy
更新時間 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
瀏覽: 1697   回覆: 1
Smart watering not working
更新時間 2024-09-10 16:17:51 UTC
瀏覽: 1777   回覆: 1
Broken whisperer sensor
Jesús López
更新時間 2024-09-09 16:19:33 UTC
Hi everyone!
瀏覽: 1868   回覆: 2
Discrepancia APP y WEB
JM del Amo
更新時間 2024-09-07 13:06:53 UTC
瀏覽: 1810   回覆: 1
1 valve works, two don't
Phil Rubin
更新時間 2024-08-17 21:52:30 UTC
瀏覽: 1922   回覆: 1
Zone watering while disabled
Brian Paternostro Paternostro
更新時間 2024-07-31 10:10:11 UTC
I am doing yard work to 2 of my 3 zones right now and have the whole system disabled for several days as many heads are disconnected.  Woke up a 5am to have zone 3 on and spraying water everywhere for 20 minutes.
How is this possible? Why do you not update your softwar?
瀏覽: 2282   回覆: 2
Error E1
Simone Ragnolini
更新時間 2024-07-26 11:13:02 UTC
Ho, we need support, as we are having an issue as the app doesn’t activate watering. The control unot shows E1.
瀏覽: 2002   回覆: 1
La zona non si spegne
Gmultis
更新時間 2024-07-17 16:29:38 UTC
Quando collego la valvola la zona resta alimentata a 24 v anche quando finisce il ciclo. Quindi non smette di irrigare anche con la spia di colore verde.
Senza la valvola invece la tensione torna 0 volt.
Cosa può essere il problema
瀏覽: 2112   回覆: 2
Problem with irrigation time
Daniel Encinas
更新時間 2024-07-12 10:43:36 UTC
Hello, I have owned a Netro Sprite programmer for several years.
The problem I have is that it programs the phases intelligently and if it indicates that it has to water for 10 minutes. It only waters for about 1 minute but the app shows that it has watered for 10 minutes. The garden is drying out and I don't know what to do.
This happens to me in all irrigation phases. If I program it manually the same thing happens to me. If I try it twice, the second time it takes even less time to water.
I have connected the transformer directly to the phase, bypassing the programmer, and it works correctly.
Reviewing its problems section, I found a similar one in which it says to look at the 24 volt voltage. (which is correct, around 30 volt) and the resistance in ohms of more than 20 (around 30 ohmios). It also says that there the programmer has a recoverable fuse.
What can I do?
瀏覽: 2134   回覆: 1
