Can't get desired watering time
Fabio Silvestri
更新時間 2024-07-24 19:24:30 UTC
I'm struggling to setup watering time, even after third season im using this app.
As per my settings, EPA suggest to water every day, 30 minutes a day for each zone. The grass is getting sick as all past 2 years, cause the frequency is too high.
I would expect it to water for 1 hour, each 3-4 days. This is what i call "deep watering".
I tried following settings, the frequency decreases, but no way that i can increase the watering time which remains 30 minutes.
Help please
瀏覽: 3200   回覆: 1
Error E1
Simone Ragnolini
更新時間 2024-07-26 11:13:02 UTC
Ho, we need support, as we are having an issue as the app doesn’t activate watering. The control unot shows E1.
瀏覽: 3119   回覆: 1
Watering system turns on by itself?
Michael Collins
更新時間 2024-07-27 23:34:54 UTC
I have the following odd situations:
1. The Netro does not show any watering activity.
2. My watering system is turning on by itself, and one of my zones is just firing away, spreading water for hours on end.
3. The Netro does not seem to be be able to stop it or even show that it's running.
4. Unplugging the Netro did fix the problem. Even more bizarre
I have an old Netro that never did this. I wonder if I should just swap them out?  This newest one seems to bug sometimes?
Any thoughts what could be doing this?
瀏覽: 3166   回覆: 2
Sensor plat
Tiago Lourenco
更新時間 2024-07-28 12:17:00 UTC
Good afternoon
I have plant sensors in all zones, and they block.
Sometimes i have my grass really dry and the sensor have 70/80 % of humidity.
I turn them off change place like 2 cm, turn them in again and they have the correct humidity.
Anyone experience this?
Thank you in advance
瀏覽: 3319   回覆: 3
Boost factor in app
Jorge Castrillo
更新時間 2024-07-30 13:55:17 UTC
瀏覽: 3241   回覆: 1
Zone watering while disabled
Brian Paternostro Paternostro
更新時間 2024-07-31 10:10:11 UTC
I am doing yard work to 2 of my 3 zones right now and have the whole system disabled for several days as many heads are disconnected.  Woke up a 5am to have zone 3 on and spraying water everywhere for 20 minutes.
How is this possible? Why do you not update your softwar?
瀏覽: 3381   回覆: 2
2 hub-1 in my house
Troy Guinn
更新時間 2024-08-09 00:15:52 UTC
I have 2 pixe devices and 2 hubs. I have 1 hub and pixie working fine. When I added the 2nd hub it does not show up in the app and therefore cannot add the 2nd pixie what am I doing wrong
瀏覽: 3167   回覆: 1
deleting plant sensor
David Ridgwell
更新時間 2024-08-10 01:31:44 UTC
deleting plant sensor??
瀏覽: 3070   回覆: 1
Terminal 1 not working
Morgans_Home
更新時間 2024-08-12 01:27:03 UTC
瀏覽: 3010   回覆: 1
Smart watering very stupid
Ruth Wengert
更新時間 2024-08-13 14:22:33 UTC
瀏覽: 3025   回覆: 1
Van Klaveren Patrick
更新時間 2024-08-15 10:04:53 UTC
瀏覽: 2962   回覆: 1
Riego
Felipe Martinez Cuadrado
更新時間 2024-08-16 21:16:23 UTC
He instalado el programador y de vez en cuando salta una de las zonas
瀏覽: 3018   回覆: 1
1 valve works, two don't
Phil Rubin
更新時間 2024-08-17 21:52:30 UTC
瀏覽: 3044   回覆: 1
problematiche app
Giampaolo Mariani
更新時間 2024-08-20 08:16:25 UTC
瀏覽: 3051   回覆: 1
Ac adaptor
Cisco -
更新時間 2024-08-24 21:45:58 UTC
瀏覽: 2863   回覆: 1
Replace controller
paul.robinson@bigbend.net
更新時間 2024-08-24 22:53:15 UTC
瀏覽: 2906   回覆: 1
Wunderground
PPL
更新時間 2024-09-02 17:42:25 UTC
瀏覽: 2853   回覆: 1
Tie the irrigation of two lines on the same garden
Francesco
更新時間 2024-09-04 07:59:17 UTC
I have two irrigation lines on the same garden, is there any setting that would allow these two areas to be “tied together” such that they irrigate on the same day (session)? (Obviously first one line and then the other).
瀏覽: 2983   回覆: 1
Discrepancia APP y WEB
JM del Amo
更新時間 2024-09-07 13:06:53 UTC
瀏覽: 2874   回覆: 1
Pierluigi Cilli
更新時間 2024-09-08 07:29:59 UTC
瀏覽: 2909   回覆: 1
