Broken whisperer sensor
Jesús López
更新時間 2024-09-09 16:19:33 UTC
Hi everyone!
瀏覽: 3004   回覆: 2
Smart watering not working
更新時間 2024-09-10 16:17:51 UTC
瀏覽: 2849   回覆: 1
Sensor
Kathleen Hamilton
更新時間 2024-09-11 19:43:50 UTC
瀏覽: 2902   回覆: 1
Thomas Murphy
更新時間 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
瀏覽: 2781   回覆: 1
Zone 1 not watering
11807GFT
更新時間 2024-09-24 23:25:59 UTC
瀏覽: 2770   回覆: 1
Schedules
jonathansalina
更新時間 2024-09-28 11:11:52 UTC
瀏覽: 2703   回覆: 1
How do I?
Rockhead413
更新時間 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
瀏覽: 2646   回覆: 1
1 zone not watering
cowlo@xtra.co.nz
更新時間 2024-10-01 01:41:13 UTC
瀏覽: 2861   回覆: 1
Manual mode without delay
Phil Houghton
更新時間 2024-10-04 23:27:59 UTC
瀏覽: 2565   回覆: 1
cjulian
更新時間 2024-10-05 18:05:09 UTC
瀏覽: 2674   回覆: 1
Set up weather underground
Giovannini Alex
更新時間 2024-10-05 18:35:32 UTC
Alex
瀏覽: 2784   回覆: 1
Water restriction schedule problem
Carolyn Simmons
更新時間 2024-10-08 00:12:28 UTC
I cannot get the system to set up our county water restriction schedule. It is Wed and Saturday up to 10am in morning and after 6 pm at night. I would really like to run each zone once in the morning and once at night!  Any suggestions before I get fined $200.00?
瀏覽: 2718   回覆: 1
12330barryknoll
更新時間 2024-10-10 01:51:03 UTC
瀏覽: 2643   回覆: 1
BrettEnyart
更新時間 2024-10-13 18:02:06 UTC
瀏覽: 2650   回覆: 1
Conrtoler
John Zuzula
更新時間 2024-10-19 23:45:24 UTC
瀏覽: 2532   回覆: 1
Zine will not run
TJ Woods
更新時間 2024-10-27 14:40:45 UTC
瀏覽: 2792   回覆: 1
Zone won't shut off.
shoo.shoo
更新時間 2024-11-10 05:55:43 UTC
瀏覽: 2484   回覆: 1
Konrad
berlin
更新時間 2024-11-10 09:36:28 UTC
Who can help me?
Thank's
Konrad
瀏覽: 2422   回覆: 1
Netro Spark valve testing
Peter Strohmayer
更新時間 2024-11-14 13:49:20 UTC
Peter
瀏覽: 2430   回覆: 1
Solenoid does not switch off
Nath Moyes
更新時間 2024-11-15 00:49:20 UTC
Nath
瀏覽: 2489   回覆: 1
