Mike Carey
更新時間 2025-03-02 17:48:24 UTC
瀏覽: 1840   回覆: 1
Water transfer during rain
mark spencer
更新時間 2025-03-12 02:34:42 UTC
Is there a way?
瀏覽: 1697   回覆: 1
Tiempo de riego
Doyle Farm
更新時間 2025-03-16 17:30:27 UTC
Gracias Marcelo
瀏覽: 1665   回覆: 1
Greenhouse
Perry en Louise Mevissen
更新時間 2025-03-22 08:43:22 UTC
One of our sectors runs inside a greenhouse now. Apart from soil type and sprinkler head type, does anyone have advice how to optimise sector settings for this situation? I feel the influence of sun and normal outdoor temperature is different, and rain is completely absent in this sector.
May I suggest to add some sector setting that it is inside a greenhouse?
Perry
瀏覽: 1788   回覆: 1
Dutch language improvement
更新時間 2025-03-22 08:54:24 UTC
Kind regards,
Perry
瀏覽: 1681   回覆: 1
Netro Whisperer gen2 4 zones
Luca Gennuso
更新時間 2025-03-25 22:22:40 UTC
瀏覽: 1794   回覆: 1
New Whispere
更新時間 2025-03-31 21:05:02 UTC
What should I do ?
瀏覽: 1578   回覆: 1
Robert Greenwood
更新時間 2025-04-06 18:47:24 UTC
瀏覽: 1550   回覆: 1
Matt
更新時間 2025-04-08 16:25:11 UTC
瀏覽: 1525   回覆: 1
sdt_babel
更新時間 2025-04-08 17:57:42 UTC
瀏覽: 1699   回覆: 1
Google Home Assistant
Eric Jonsson
更新時間 2025-04-19 07:46:16 UTC
Eric
瀏覽: 1514   回覆: 1
24 hrs
Eric Jonsson
更新時間 2025-04-19 08:19:24 UTC
瀏覽: 1666   回覆: 1
Andrea DS
更新時間 2025-04-22 12:33:21 UTC
瀏覽: 1511   回覆: 1
Garden Bib
Grant Sullivan
更新時間 2025-04-22 22:01:02 UTC
瀏覽: 1595   回覆: 1
Whisperer 2
Stephen Brewer
更新時間 2025-04-24 13:43:01 UTC
Steve
瀏覽: 1428   回覆: 1
Server Down 4/27/25?
更新時間 2025-04-27 19:38:18 UTC
瀏覽: 1572   回覆: 5
Irrigation system service
Rick Joseph
更新時間 2025-04-27 19:53:45 UTC
瀏覽: 1348   回覆: 0
does not irrigate
Giovanni Asoni
更新時間 2025-04-28 15:58:30 UTC
瀏覽: 1594   回覆: 1
IFTTT Trigger for moisture
Kareo
更新時間 2025-04-29 04:50:52 UTC
瀏覽: 1587   回覆: 2
Soil and weather
Stephen Brewer
更新時間 2025-04-29 10:06:27 UTC
Steve
瀏覽: 1661   回覆: 1
