Ricardo Ribeiro
更新時間 2025-07-12 13:05:48 UTC
Can you help?
瀏覽: 762   回覆: 1
nsutherland
更新時間 2025-07-14 01:33:11 UTC
瀏覽: 759   回覆: 1
Andrew Woods
更新時間 2025-07-22 19:30:55 UTC
瀏覽: 595   回覆: 0
Interpretation of soil moisture readings by Whisperer
Missy Bartell
更新時間 2025-07-26 12:13:30 UTC
I have two Whisperers that I move around to various parts of my graden to get comparative readings of sunlight and soil moisture.  I really do not know how to interpret the moisture readings which generally range from 50% to 98% but can be as low as 30%.  Soil type varies from a clayey loam to heavy clay.   How do I know when watering is required?  Does the meter measure the capillary water?  The adhered water?  The percentage of voids filled with water?  How does Netro calculate the percentage of water and what do the readings mean?
瀏覽: 1   回覆: 0
New app (Android)
Ken Jennings
更新時間 2018-06-08 16:39:10 UTC
瀏覽: 6819   回覆: 1
Great job Team!
robertj51
更新時間 2018-06-11 17:43:40 UTC
This is a great product with a great application as well. Thanks to the team and the developers for working hard to make this right. This is fantastic!
瀏覽: 6024   回覆: 1
Weather override
U Koul
更新時間 2018-06-15 17:39:02 UTC
瀏覽: 6124   回覆: 3
Subsoil Moisture-Netro app
Rick Priory
更新時間 2018-06-16 13:09:48 UTC
瀏覽: 5654   回覆: 1
Soil type?
John Broadbent
更新時間 2018-06-16 14:27:36 UTC
瀏覽: 7515   回覆: 2
Two locations
Robert Garlick
更新時間 2018-06-22 13:31:35 UTC
I have a system working in Florida and I just wanted to do the same thing in Kansas and I bought it and I have wired it but I haven't plugged it in because I don't know how I'm going to control each different location and I'm afraid something might go wrong and I won't be able to water in Florida.
So how do I control each separate location with the same phone?
瀏覽: 5743   回覆: 1
Scheduling
Richard Hall
更新時間 2018-07-09 15:56:46 UTC
瀏覽: 5547   回覆: 1
Smart zone watering some zones multiple times
Jason Warren
更新時間 2018-07-10 11:29:26 UTC
I have eight zones with smart watering enabled for all zones. I noticed this morning when looking at scheduling that a few of the zones will water multiple times in the same morning. For example, Zone one will water for 4 minutes, Zone 2, Zone 3 excetera. Then it goes back to Zone 1 for 3 minutes, and maybe zone for for 7 minutes. Is this normal?
I have inserted a screen shot.Notice the zone, "house left."
瀏覽: 5605   回覆: 1
Manual Watering
Steve
更新時間 2018-07-10 17:54:41 UTC
瀏覽: 6114   回覆: 2
Never waters lawn
Mossy Bank
更新時間 2018-07-12 01:52:11 UTC
I have had the netro for a  week and it has yet to water the lawn. Today, it states 12 more days until the next water. I have Bermuda grass in Alabama, it is 90+ degrees daily. Seems like it will never water. It has only rained for 5 minutes the last week, but the app thinks it has rained more often.
瀏覽: 5385   回覆: 2
Smart vs. manual program
Mike Bujor
更新時間 2018-07-13 22:36:12 UTC
Hi just wanted to know if I running only customs programs for watering I can take advantage of the Smart Watering feature. In other words, I only have my own watering program, NO smart programs, and need to know if the controller will skip these programs when raining. If NOT will the sensor allow provide that feature?
Thx - Mike
瀏覽: 5847   回覆: 3
Same Zone Settings, Different Results
bmcginni
更新時間 2018-07-14 11:23:00 UTC
Hello - I have a 9 zone system. I have set all of the zones with the exact same settings for type, grass, etc. I do not have any sensors.
However, the app shows the zones having different moisture levels, and waters certain zones differently than others, even though the settings and system location are the exact same.
Can you help me understand why the system would treat these identically programmed zones differently
瀏覽: 5651   回覆: 1
EPA Recommendations
bmcginni
更新時間 2018-07-14 11:30:12 UTC
In the zone settings, the app offers different types of watering, for example, regular, deep watering, boost, etc. One is labeled EPA.
What are the differences between the settings and watering times/amounts for: regular, boost, and EPA?
瀏覽: 5654   回覆: 1
Netro app fails to run
Duncan Krause
更新時間 2018-07-29 17:50:52 UTC
Any ideas
瀏覽: 5456   回覆: 1
Two zones on same spot
更新時間 2018-07-31 22:06:08 UTC
I have 4 zones. Two of these cover the same piece of ground. One zone has pgm sprayers and the other zone has regular sprayers .But they cover exactly the same area. How do I tell the app this so that it knows that running the sprinklers for one zone waters the same trees and grass as the other zone?
To try and clarify the question - these zones cover the same physical piece of ground, (they overlap 100%) but netro doesn't know that, so it will water one zone and think the other zone is still in need of watering - and thus water the same grass twice. (each zone once so the same grass twice).  Netro's algorithm for determining soil moisture levels can't work if it doesn't realize these two zones are the same physical piece of grass.
瀏覽: 5833   回覆: 2
Accuracy of dark sky in Canada
更新時間 2018-07-31 03:16:54 UTC
The dark sky android app is not available in Canada  so I wonder how accurate their weather is here.  To try and determine this for myself, I looked at the netro temperature graph..  Today it is 34C at my house  but the temperature summary graph in  Netro says it is only 22C. (for my friends still using Fahrenheit that is about a 24F difference )  Does anyone know when Netro gets the temperature that it uses in the graph? Other thoughts on dark sky accuracy in Canada?
瀏覽: 5624   回覆: 1
