St. Augustine
Spencer Vaughn
更新時間 2019-01-10 03:15:53
瀏覽: 5442   回覆: 2
Tim Cox
更新時間 2019-02-02 01:35:59
瀏覽: 4874   回覆: 3
Nathan Anderson
更新時間 2019-02-13 03:53:31
瀏覽: 4833   回覆: 1
Scot and Michelle Cowan
更新時間 2019-03-03 17:04:51
瀏覽: 5192   回覆: 1
Instructions about Replacing Toro System
更新時間 2019-03-20 08:07:29
Replacing Toro system
This page lists some instructions about replacing the common types of Toro system with Netro smart watering controller.
Example 1:
Toro model gk212-04
1. Connect the 2 white wires to the C slots, one on the left and the other on the right which is now occupied by a red one.
2. Move the red wire(currently on C slot) to M slot because it is for your master valve.
3. The last step is to connect the power then you should be good to go.
Example 2:
Toro IC 8.
The first slot of your current controller is master valve which should be connected  to "M" slot of Netro. The two wires in the second slot are common wires should be connected to the 'C' slot of Netro. The last step is to connect the power then you should be good to go.
Example 3:
Toro Model 53765 6 zones
The red and white wires are the commons wires and should go to the two "C" slots in Netro Sprite controller. You do not need to connect the gray and black wires as they are the power wires for the old controller.
瀏覽: 6536   回覆: 0
更新時間 2019-03-20 08:03:05
Replacing old system
Example 1:
I check the pictures.
OLD                 Sprite
COM                any C slot
1                     1
2                     2
3                     3
4                     4
Example 2:
Example 3:
Example 4:
Other wires are not needed.
Example 5:
瀏覽: 5154   回覆: 0
Overriding smart waterinh
mvernia
更新時間 2019-03-17 20:46:27
瀏覽: 4487   回覆: 1
charu
更新時間 2019-03-21 16:27:21
瀏覽: 4352   回覆: 1
Not able to water
更新時間 2019-03-27 13:18:49
瀏覽: 4776   回覆: 1
controller firmware
Magnus Swenson
更新時間 2019-03-27 19:55:40
Does the controller update its own firmware automatically on a specific schedule or you push out when needed?
瀏覽: 4963   回覆: 1
windy conditions
Magnus Swenson
更新時間 2019-03-27 20:05:53
The setting for windy conditions is great.
However the zones that includes drip irrigation doesn’t get impacted by winds (since they’re often under dirt/mulch etc) usually rotors and nozzles would be impacted . Is there a way not to include in ground drip irrigation on windy conditions?
瀏覽: 4517   回覆: 1
MAC address
Lee Hill
更新時間 2019-03-29 15:45:44
瀏覽: 4692   回覆: 1
Smart home integration
Matt Griste
更新時間 2019-03-29 22:29:57
瀏覽: 4922   回覆: 2
Smart Watering Basic with a schedule watering adjustment
Barry Perfect
更新時間 2019-04-13 17:00:37
If I have a zone set to Smart Watering - Basic with a schedule to come on for 30 minutes, will the smart watering adjust the duration of the watering based on the weather (say 10 minutes when it’s cool, the full 30 minutes when it is hot), or just turn it off/on based on the 5mm expected rain threshold?
Barry
瀏覽: 4389   回覆: 1
Suggestion: Sunrise smart watering
Mark S
更新時間 2019-04-15 13:39:43
I think Rachio adjusts the watering schedule with sunrise to have all zones completed as the sun is coming up. Is this something you intend to add? I think this will come in handy with the heat of summer.
瀏覽: 4568   回覆: 1
更新時間 2019-04-20 12:21:46
Mr Bad Example
瀏覽: 4769   回覆: 1
Weather Company API- Revenue stream for Netro
更新時間 2019-04-20 12:58:20
It is my understanding that you could restore our ability to pull data into netro from our individual weather stations. This would require paying for the API, which you could mark up 20% and offer a paid option to netro clients. $3.99 a year, for example, would be totally worth it to get accurate information to my sprinkler controller. As I have outlined in a previous post, dark sky has proven to be wildly inaccurate. It's Miss estimates rainfall by at least 50%, on average, and is within three degrees plus or minus on high temperature only about 50% of the time.
瀏覽: 5448   回覆: 4
John Mac
更新時間 2019-04-22 23:42:30
瀏覽: 4324   回覆: 1
Alexa
Emilio Maione
更新時間 2019-04-24 06:50:56
瀏覽: 4556   回覆: 1
Answers?
Howard Blankenship
更新時間 2019-04-24 14:46:54
瀏覽: 4234   回覆: 1
