Manual mode fail to shut off
更新時間 2019-05-16 02:05:13 UTC
瀏覽: 4922   回覆: 1
Whisperer stopped working
Pelle Fisk
更新時間 2019-05-17 13:30:13 UTC
瀏覽: 5433   回覆: 2
Hot weather algorithm
Joshua Berk
更新時間 2019-05-17 16:15:51 UTC
瀏覽: 5040   回覆: 2
Steven V
更新時間 2019-05-18 13:08:55 UTC
瀏覽: 4575   回覆: 1
David Claridge
更新時間 2019-05-18 13:21:53 UTC
瀏覽: 4611   回覆: 1
Dennis N
更新時間 2019-05-18 17:52:30 UTC
瀏覽: 4542   回覆: 1
Roianne Cox
更新時間 2019-05-19 13:52:50 UTC
瀏覽: 4503   回覆: 1
jpmeyer81
更新時間 2019-05-19 15:04:11 UTC
瀏覽: 4916   回覆: 1
Manually skip next watering
Randy Ziffer
更新時間 2019-05-19 16:47:13 UTC
瀏覽: 4772   回覆: 2
Remote Access?
Oliver Pettit
更新時間 2019-05-22 01:53:35 UTC
Oliver
瀏覽: 5121   回覆: 1
Can't see answers to questions
Stan Bumgarner
更新時間 2019-05-23 00:30:01 UTC
I can see the question and can see that someone has answered it. How do I see the answer?
Stan
瀏覽: 4599   回覆: 1
Joshua Berk
更新時間 2019-05-23 18:39:21 UTC
瀏覽: 4912   回覆: 1
Netro off line
更新時間 2019-05-25 02:59:21 UTC
瀏覽: 5035   回覆: 1
Don’t Stop !!
Eduardo Ariste
更新時間 2019-05-26 11:27:42 UTC
瀏覽: 4505   回覆: 1
Jon Storch
更新時間 2019-05-27 19:41:14 UTC
Why did it run this morning?
Jon Storch
瀏覽: 5422   回覆: 1
Subsoil moisture level
Swaroop Jay
更新時間 2019-05-28 17:13:12 UTC
瀏覽: 4793   回覆: 2
Zones
José Miguel Salcedo
更新時間 2019-05-28 20:03:07 UTC
Why  can't I water two zones at the same time
瀏覽: 4800   回覆: 1
Netro offline and not watering
Mark
更新時間 2019-05-28 22:23:43 UTC
netro shows offline.  The app says zones are watering but no watering is occurring.   Plants are dying.
Retro device has a white light.
How do I fix this?
瀏覽: 4375   回覆: 0
Using as a on/off switch
pgvolk
更新時間 2019-05-29 14:59:55 UTC
瀏覽: 4758   回覆: 1
shaneduan
更新時間 2019-05-30 15:57:58 UTC
Maybe I missed something....
瀏覽: 4662   回覆: 1
