WiFi connection
Andrew
更新時間 2019-06-27 00:49:26 UTC
瀏覽: 4373   回覆: 0
Whisper shipping
Matty B
更新時間 2019-06-30 13:31:58 UTC
I ordered a sensor and have yet to receive it. It has been well past 4 weeks.
Number is: 180404 ― May 17, 2019
What is the status of the order?
瀏覽: 5060   回覆: 2
internet may not be available
Bruce Vermeulen
更新時間 2019-06-30 18:31:02 UTC
Bruce
瀏覽: 4542   回覆: 0
Nipun Devlekar
更新時間 2019-07-01 01:01:18 UTC
瀏覽: 4442   回覆: 1
Adapter in EU
Lukas2002
更新時間 2019-07-01 11:06:15 UTC
I am Lukas from the Netherlands. I have ordered a Netro sprite-6 on without a power adapter.
In the Netherlands we have 230V AC on the power grid. I am having serious trouble to find a power adapter that goes to 24V AC 800mA.
The only one I can find has an output of  24V AC 1000mA, will that be ok?
Or is there a better alternative out there?
Lukas Zwanenburg (NL)
瀏覽: 5065   回覆: 2
更新時間 2019-07-01 16:32:17 UTC
瀏覽: 4981   回覆: 1
Notifiche push
Andrea Casali
更新時間 2019-07-01 19:07:47 UTC
Ciao, è possibile ricevere delle notifiche push tutte le volte che parte l’irrigazione?
瀏覽: 4688   回覆: 1
Rain versus no rain
Dennis G
更新時間 2019-07-03 03:27:38 UTC
瀏覽: 4854   回覆: 1
Forecast provider for Italy
Gabriele Gianello
更新時間 2019-07-03 11:53:03 UTC
瀏覽: 5075   回覆: 1
Smart watering
John Jessee
更新時間 2019-07-03 22:25:57 UTC
瀏覽: 4517   回覆: 1
Saurik
更新時間 2019-07-04 07:12:42 UTC
瀏覽: 4715   回覆: 1
Home Assistant
David
更新時間 2019-07-06 09:33:48 UTC
瀏覽: 4897   回覆: 1
Reset Moisture Level
firewally
更新時間 2019-07-06 14:06:03 UTC
瀏覽: 4835   回覆: 1
更新時間 2019-07-07 14:40:49 UTC
瀏覽: 5767   回覆: 1
Doug Clark
更新時間 2019-07-07 18:06:07 UTC
This isn’t AI!
瀏覽: 4824   回覆: 1
How to change zip code in the addres in the setting/controller
sorondo
更新時間 2019-07-09 07:50:41 UTC
How to change zip code in the addres in the setting/controller?
By mistake I nitroduced a wrong zip code in the address of the controller... How can I change it? Do I have to remove the controller and inmediatelly to add a new one? Thanks.
Jcgc
瀏覽: 5160   回覆: 3
Spanish language for control
sorondo
更新時間 2019-07-09 09:24:52 UTC
Jcgc
瀏覽: 4827   回覆: 1
Whisperer Test
Dan Leng
更新時間 2019-07-10 18:29:27 UTC
瀏覽: 5208   回覆: 2
Rod Timby
更新時間 2019-07-11 18:09:47 UTC
瀏覽: 4358   回覆: 0
Rod Timby
更新時間 2019-07-11 18:14:39 UTC
瀏覽: 4461   回覆: 1
