Home Assistant
David
更新時間 2019-07-06 09:33:48
瀏覽: 4698   回覆: 1
Reset Moisture Level
firewally
更新時間 2019-07-06 14:06:03
瀏覽: 4641   回覆: 1
更新時間 2019-07-07 14:40:49
瀏覽: 5556   回覆: 1
Doug Clark
更新時間 2019-07-07 18:06:07
This isn’t AI!
瀏覽: 4635   回覆: 1
How to change zip code in the addres in the setting/controller
sorondo
更新時間 2019-07-09 07:50:41
How to change zip code in the addres in the setting/controller?
By mistake I nitroduced a wrong zip code in the address of the controller... How can I change it? Do I have to remove the controller and inmediatelly to add a new one? Thanks.
Jcgc
瀏覽: 4959   回覆: 3
Spanish language for control
sorondo
更新時間 2019-07-09 09:24:52
Jcgc
瀏覽: 4621   回覆: 1
Whisperer Test
Dan Leng
更新時間 2019-07-10 18:29:27
瀏覽: 4982   回覆: 2
Rod Timby
更新時間 2019-07-11 18:09:47
瀏覽: 4176   回覆: 0
Rod Timby
更新時間 2019-07-11 18:14:39
瀏覽: 4274   回覆: 1
更新時間 2019-07-12 15:05:29
瀏覽: 4924   回覆: 1
How do you stop the watering
Rick Jones
更新時間 2019-07-13 16:02:14
瀏覽: 4307   回覆: 1
Netro + Netatmo
Luca Magnani
更新時間 2019-07-14 07:42:29
Good morning
I have a netatmo weather station,
it would be nice to connect it to read the weather data precisely for my area.
Thank you in advance
瀏覽: 6084   回覆: 1
No light
Gilbert Lee
更新時間 2019-07-14 15:37:53
瀏覽: 4469   回覆: 1
Location Based Watering Restrictions - Check-in Interval
Matt Grooms
更新時間 2019-07-14 18:58:52
One of the great features of Netro is it's ability to look up my local (city/state) watering regulations, and apply them to my watering schedule. Bravo Netro!
Months ago, when I installed my Netro controller it looked up the then current (Stage-One) restrictions, and applied them to my watering schedule. However, since that time the watering restrictions have been eased (Year-Round restrictions) , and I'm allowed to water any day of the week. Well, Netro did not follow the changes and is still applying the old restrictions.
I attempted to trick Netro into rereading my local restrictions by turning the feature off, then back on. No luck.
So the questions are:
1) How often does a Netro Controller check the cloud database for updated watering restriction for it's location?
2) How often does Netro Central (you guys) check with communities for watering restriction updates and update your database so that deployed Netro controllers get accurate rules to apply?
I can see where it might be hard to keep up with small communities and rural areas, but my location (San Antonio, Texas, USA) has almost two-million people in the area. A single update on your part would provide a potentially large number of Netro users with current watering restriction information.
Matt
瀏覽: 5929   回覆: 1
HomeKit?
pintapass
更新時間 2019-07-15 03:55:15
瀏覽: 5467   回覆: 3
Problems with the internet
Morrie Wayne
更新時間 2019-07-15 16:50:35
We have a hot spot for our internet connection from Verizon. The hot spot keeps going off line and we don’t know what to do to correct it. Our Netro unit is in Florida and we are in Ohio. We don’t have any one close in Florida to help us with our problem. Might there be a inexpensive internet we might be able to acquire, or do you have another solution? We appreciate any suggestions you might have. We are happy with our Netro unit. Morrie Wayne. Address in Florida is. 1673 Abasco Ct. The Villages, Florida 32162. Address In Ohio is 18379 Squirrel Run Dr, Cleveland, Ohio 44130. My cell # is 440-856-9242. Thanks for any solution to our problems.
瀏覽: 4751   回覆: 2
Introducing the Referral Program
更新時間 2019-12-10 03:02:22
To the Netro community:
We are pleased to launch the Netro Referral Program. You can earn reward points when your friends become Netro customers!
1.Invite your friends to join Netro using your unique link
2.Your friends get a discount or reward points
Your friends enjoy 10% off their first orders or $10 credits toward their first subscriptions.
3.Get your reward points and repeat to earn more
You will earn reward points* equivalent in value to the discounts or credits given to your friends.
*Reward points: for every US dollar your friends spend on their first orders you will earn 10 points ($0.1). You will earn 1000 points ($10) for every friend who chooses to subscribe. There are 3 ways to redeem the reward points:
1. Use the reward points to purchase Netro products at netrohome.com (100 points = 1 US dollar)
2. Use the reward points to pay for your subscription fee at netrohome.com (100 points = 1 US dollar)
3. Withdraw the reward points to your PayPal account (200 points = 1 US dollar)
Your reward points will never expire.
You can check more info about Netro's Referral Program here https://netrohome.com/shop/refer
瀏覽: 5083   回覆: 2
Water stops running before the cycle is over
sgschrank
更新時間 2019-07-18 18:03:03
Recently I have been having issues with zones 5-8 stop watering before the cycle is over, but keeps counting down and moves to the next zone and does the same thing. I have tried resetting the unit, re-linking the wifi, but doesn't seem to make a difference. Help!
瀏覽: 4271   回覆: 0
Whisperer and smartzone configuration
更新時間 2019-07-19 13:45:19
I have set up all the zones with the whisperers. And there is something I do not understand.
One of the zones usually get flooded in autumn because the type of soil retains lots of water.
But the whisperer and the smart zone is saying that the zone has to be watered more time than the other zones.
My question is if the whisperer adapts the irrigation schedules and the time is watering per zone. Depending on the moisture, weather conditions  and type os soil.  It is clear that the soil type determines how much and how often to water.
Here in the following link (https://www.netrohome.com/shop/products/whisperer)says that "Netro accurately measures the water capacity and drainage rate of your soil, making sure your soil always receives the perfect amount of water at the perfect time."
That is fine, but it is confusing that in the app I can still define the type of soil.
A second question I have is that I can define the watering strategy (Regular, ECO etc...) I want to know if the whisperer and the controller will notify me if I have to change the strategy based on the weather conditions and the type of soil, plants etc...
Any idea?
瀏覽: 5120   回覆: 1
Netro Whisperer
Christopher Martinez
更新時間 2019-07-24 06:20:37
瀏覽: 4588   回覆: 2
