OnePlus Venom
更新時間 2019-07-29 03:48:51 UTC
What does that mean???
瀏覽: 4603   回覆: 1
Low pressure in zones
Hussein Diab
更新時間 2019-07-29 16:36:31 UTC
瀏覽: 4528   回覆: 1
water amount
Gérard GALBOIS
更新時間 2019-07-31 05:37:55 UTC
瀏覽: 4356   回覆: 1
Where's our promised update?
更新時間 2019-07-31 11:19:38 UTC
瀏覽: 4757   回覆: 1
Promise Made- Promise KEPT!
更新時間 2019-08-03 04:32:30 UTC
瀏覽: 4673   回覆: 0
Can my whisper control 2 zones?
L F
更新時間 2019-08-04 02:09:24 UTC
I have two zones for the grass in my backyard and want to connect 1 whisper for both zones since its one small piece of grass.  How can I do this?
瀏覽: 4617   回覆: 1
sprite losing connection
Robert hays
更新時間 2019-08-04 15:42:10 UTC
瀏覽: 4536   回覆: 1
Install
Daniel Alman
更新時間 2019-08-05 15:17:08 UTC
瀏覽: 4512   回覆: 1
changing watering zone times?
更新時間 2019-08-06 01:53:14 UTC
瀏覽: 4593   回覆: 1
更新時間 2019-08-06 11:03:17 UTC
瀏覽: 4643   回覆: 1
Sprite doesn't open valve
Tony D.
更新時間 2019-08-06 20:38:31 UTC
瀏覽: 5061   回覆: 1
itsthesun
更新時間 2019-08-06 20:42:23 UTC
瀏覽: 4653   回覆: 1
Runs for 9 hours at a time
Cindy Luvender
更新時間 2019-08-07 00:27:20 UTC
瀏覽: 4569   回覆: 1
Suport MQTT? Suport REST API?
Sergio Albarran Rebull
更新時間 2019-08-09 14:25:13 UTC
Suport MQTT?
Suport REST API?
Thanks in advance...
瀏覽: 5270   回覆: 5
Zip code
Homestead One
更新時間 2019-08-10 11:09:29 UTC
瀏覽: 4467   回覆: 0
Spanish translation
Juan P
更新時間 2019-08-10 21:48:16 UTC
瀏覽: 5202   回覆: 3
Update application
Anyhony Harwood
更新時間 2019-08-11 11:58:55 UTC
瀏覽: 4289   回覆: 1
Unexpected smart schedule
Tony D.
更新時間 2019-08-12 09:35:56 UTC
- zone 1: 6:00 16 min.
- zone 2: 6:17 15 min.
- zone 1: 6:46 16 min.
- zone 2: 7:02: 15 min.
UPDATE
Thank you in advance,
Tony
瀏覽: 4809   回覆: 1
One day restriction
Lou Infeld
更新時間 2019-08-12 21:49:14 UTC
瀏覽: 4523   回覆: 1
Removing plant sensor
Alessia
更新時間 2019-08-14 20:41:19 UTC
Hello, how can i remove the plant sensor which i added for error?
瀏覽: 4694   回覆: 1
