Delivering term please
yodiego
更新時間 2020-03-14 18:08:21
瀏覽: 3845   回覆: 1
Whisperer issue
Saul Perez
更新時間 2020-03-15 19:07:50
瀏覽: 4075   回覆: 1
Javier Palomino
更新時間 2020-03-18 02:11:35
瀏覽: 3987   回覆: 1
stefano banfi gaslini
更新時間 2020-03-18 15:16:20
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
瀏覽: 4130   回覆: 1
Instalación wifi
Eduardo Pariente
更新時間 2020-03-20 16:15:47
Good afternoon.
 I have problems because I don't recognize the wifi.  I'll explain. First I connect by wifi to netro and it does not give me any problems.  But when I go back to the next screen to connect the mobile to the wifi and the wifi from home no longer appears. He's gone. And I can't continue with the installation.
瀏覽: 4149   回覆: 1
Yohan
更新時間 2020-03-22 00:49:00
瀏覽: 4177   回覆: 1
Smart scheduling problem
更新時間 2020-03-23 19:15:51
This is my set up.
1) why this happened?
瀏覽: 4516   回覆: 1
Giacomo
更新時間 2020-03-24 14:44:34
Thanks in advance
瀏覽: 4678   回覆: 1
J H
更新時間 2020-03-24 21:16:47
瀏覽: 3974   回覆: 1
Garden
Steven Carnie
更新時間 2020-03-26 14:53:02
瀏覽: 5209   回覆: 1
Max V
更新時間 2020-03-27 18:52:10
Hi everyone!
瀏覽: 4977   回覆: 1
duerson
更新時間 2020-03-27 20:59:20
瀏覽: 4185   回覆: 1
2 or more zone at same time
Mirko Paganelli
更新時間 2020-03-28 15:32:05
瀏覽: 4101   回覆: 1
Run Netro in one zone now
Stan Bumgarner
更新時間 2020-03-28 20:15:35
Stan
瀏覽: 3955   回覆: 1
Rain adjustment
Arvind Ramanadham
更新時間 2020-03-31 19:10:38
瀏覽: 4372   回覆: 1
Dark Sky
Vardhan Rajkumar
更新時間 2020-04-01 21:55:47
瀏覽: 4480   回覆: 2
Installing Pixie
kristinsavage
更新時間 2020-04-03 21:25:20
I am trying to install my Netro Pixie and the vacuum breaker is blocking the filter on the Pixie. Any suggestions?
瀏覽: 4250   回覆: 1
power adaptor
更新時間 2020-04-04 14:39:25
just received a Netro Sprite controller 12 sone without power adapter
I am in Rome , Italy
We have 240 volts energy supply
what adapter have i to buy ?
thanks
paolo
瀏覽: 4456   回覆: 2
Joe Ryan
更新時間 2020-04-05 17:48:32
瀏覽: 4311   回覆: 1
Casey S
更新時間 2020-04-05 19:41:30
瀏覽: 4363   回覆: 1
