Home Assistant integration
Casey S
更新時間 2020-04-05 19:46:53
瀏覽: 4543   回覆: 2
Host mode
Luca Manfrin
更新時間 2020-04-06 17:55:38
What is host mode?
瀏覽: 4346   回覆: 1
Settings
Massimo Povolo
更新時間 2020-04-07 06:31:48
瀏覽: 4612   回覆: 5
Luca Manfrin
更新時間 2020-04-07 09:19:37
瀏覽: 4179   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:22:40
瀏覽: 4289   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:28:22
瀏覽: 4282   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:33:03
瀏覽: 4120   回覆: 1
Irrigation time of 0 minutes. then?
Luca Manfrin
更新時間 2020-04-07 09:37:54
What's the point option to set the irrigation time at 0 minutes in manual execution?
It would be more useful a 30 seconds run for testing the valves.
瀏覽: 4282   回覆: 1
Luca Manfrin
更新時間 2020-04-07 10:07:29
-SKIP FOR TODAY
瀏覽: 4128   回覆: 1
Irrigation time striketrough
Luca Manfrin
更新時間 2020-04-07 12:34:22
thank you
瀏覽: 4128   回覆: 1
Seb Cruzer
更新時間 2020-04-07 15:03:43
hello,
Please help!
瀏覽: 4375   回覆: 2
Power adapter - eu
David B.
更新時間 2020-04-08 13:43:20
I have a netro sprite with an original power adapter.
How ca i connet this to my 220/230 Volt energynet in Austria pls?
A normal Adapter will not work since i have to tansform volt and ampere to 800ma and 110volt as far as i could find informations.
Kind regards david
瀏覽: 4306   回覆: 1
Resetting Netro Whisperer
Patrick
更新時間 2020-04-09 19:34:52
瀏覽: 5522   回覆: 1
Incorrect weather conditions
Andrea Merito
更新時間 2020-04-09 20:33:11
as the state / province is changed because Madrid is specified instead of Catania, consequently the weather is incorrect.
瀏覽: 4221   回覆: 1
Luca Manfrin
更新時間 2020-04-10 11:43:03
瀏覽: 4568   回覆: 2
Netro app on google home
Danilo
更新時間 2020-04-11 10:07:58
Thanks for your support.
瀏覽: 4004   回覆: 1
Brett Lilly
更新時間 2020-04-13 18:42:28
瀏覽: 4133   回覆: 1
Faucet Connector Broke
Larry Griggers
更新時間 2020-04-14 18:49:27
I was having difficulty getting a leakproof seal when attaching my Smart Hose Faucet Timer (Pixie-1) to my new faucet. I finally was able to tighten it tight enough not to leak, but after a week, it broke and popped off. It is probably under warranty, but is there somewhere I can buy a new connector and repair it myself?
瀏覽: 4093   回覆: 1
Luca Manfrin
更新時間 2020-04-16 07:47:25
Thank you for your support
瀏覽: 4193   回覆: 2
Luca Manfrin
更新時間 2020-04-16 10:23:31
thank you
瀏覽: 4259   回覆: 1
