Pressure compensated drip hose
Simon Clark
更新時間 2020-05-24 17:22:21
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
瀏覽: 4409   回覆: 0
Chris Graham
更新時間 2020-05-24 20:37:39
瀏覽: 4567   回覆: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
更新時間 2020-05-24 20:43:23
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
瀏覽: 4596   回覆: 1
更新時間 2020-05-25 16:08:09
瀏覽: 4265   回覆: 1
Web interface
Emanuele Floridia
更新時間 2020-05-27 16:58:10
瀏覽: 4320   回覆: 1
Delay between zones
Nicholas Lydakis
更新時間 2020-05-28 15:39:00
瀏覽: 4091   回覆: 1
baijuviswam
更新時間 2020-05-28 18:56:02
瀏覽: 3963   回覆: 1
Jesse For
更新時間 2020-05-29 08:33:36
瀏覽: 4004   回覆: 1
Missing Whisperer
guags99
更新時間 2020-05-29 18:11:36
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
瀏覽: 4101   回覆: 1
Smart things?
S D
更新時間 2020-06-01 23:14:05
瀏覽: 3706   回覆: 0
Moisture to Skip Watering
更新時間 2020-06-02 23:59:08
瀏覽: 4151   回覆: 1
Netro Sprite non apre le valvole
Simone Nolletti
更新時間 2020-06-03 09:40:36
valvole hunter 24vac, netro non apre le valvole.
i collegamenti sono stati eseguiti come da istruzioni.
Quale può essere il problema?
Alimentatore 24v 1000ma e’ corretto?
瀏覽: 4326   回覆: 1
Watering metrics question
Egan
更新時間 2020-06-03 16:09:22
Todd in Texas
瀏覽: 4363   回覆: 2
Metrosideros (Myrtaceae)
Alessandro Raffi
更新時間 2020-06-03 21:09:16
Thanks a lot,
Ale
瀏覽: 5220   回覆: 1
Notes section per zone
Simon Clark
更新時間 2020-06-04 07:13:33
瀏覽: 4108   回覆: 1
Timer
Gary Niederpruem
更新時間 2020-06-04 12:08:43
瀏覽: 3919   回覆: 1
Upgrading from 6 to 12 zones
Carlos Oliveira
更新時間 2020-06-05 21:10:19
瀏覽: 4139   回覆: 1
OPCIONES
Ernesto
更新時間 2020-06-06 16:01:17
瀏覽: 3873   回覆: 1
A way to dial it down
esassone
更新時間 2020-06-07 01:51:41
瀏覽: 3808   回覆: 1
Simone Nolletti
更新時間 2020-06-07 19:32:59
瀏覽: 4244   回覆: 1
