Max V
更新時間 2020-03-27 18:52:10 UTC
Hi everyone!
瀏覽: 6241   回覆: 1
duerson
更新時間 2020-03-27 20:59:20 UTC
瀏覽: 4384   回覆: 1
2 or more zone at same time
Mirko Paganelli
更新時間 2020-03-28 15:32:05 UTC
瀏覽: 4298   回覆: 1
Run Netro in one zone now
Stan Bumgarner
更新時間 2020-03-28 20:15:35 UTC
Stan
瀏覽: 4128   回覆: 1
Rain adjustment
Arvind Ramanadham
更新時間 2020-03-31 19:10:38 UTC
瀏覽: 4559   回覆: 1
Dark Sky
Vardhan Rajkumar
更新時間 2020-04-01 21:55:47 UTC
瀏覽: 4662   回覆: 2
Installing Pixie
kristinsavage
更新時間 2020-04-03 21:25:20 UTC
I am trying to install my Netro Pixie and the vacuum breaker is blocking the filter on the Pixie. Any suggestions?
瀏覽: 4429   回覆: 1
power adaptor
更新時間 2020-04-04 14:39:25 UTC
just received a Netro Sprite controller 12 sone without power adapter
I am in Rome , Italy
We have 240 volts energy supply
what adapter have i to buy ?
thanks
paolo
瀏覽: 4645   回覆: 2
Joe Ryan
更新時間 2020-04-05 17:48:32 UTC
瀏覽: 4510   回覆: 1
Casey S
更新時間 2020-04-05 19:41:30 UTC
瀏覽: 4555   回覆: 1
Home Assistant integration
Casey S
更新時間 2020-04-05 19:46:53 UTC
瀏覽: 4732   回覆: 2
Host mode
Luca Manfrin
更新時間 2020-04-06 17:55:38 UTC
What is host mode?
瀏覽: 4536   回覆: 1
Settings
Massimo Povolo
更新時間 2020-04-07 06:31:48 UTC
瀏覽: 4811   回覆: 5
Luca Manfrin
更新時間 2020-04-07 09:19:37 UTC
瀏覽: 4365   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:22:40 UTC
瀏覽: 4469   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:28:22 UTC
瀏覽: 4479   回覆: 1
Luca Manfrin
更新時間 2020-04-07 09:33:03 UTC
瀏覽: 4289   回覆: 1
Irrigation time of 0 minutes. then?
Luca Manfrin
更新時間 2020-04-07 09:37:54 UTC
What's the point option to set the irrigation time at 0 minutes in manual execution?
It would be more useful a 30 seconds run for testing the valves.
瀏覽: 4473   回覆: 1
Luca Manfrin
更新時間 2020-04-07 10:07:29 UTC
-SKIP FOR TODAY
瀏覽: 4324   回覆: 1
Irrigation time striketrough
Luca Manfrin
更新時間 2020-04-07 12:34:22 UTC
thank you
瀏覽: 4319   回覆: 1
