Link to smart light
Noam Leshem
更新時間 2020-05-16 17:53:06 UTC
瀏覽: 4456   回覆: 1
EASTBOBDAM D
更新時間 2020-05-17 13:18:19 UTC
Thanks in advance
瀏覽: 4242   回覆: 1
Yves Desrosiers
更新時間 2020-05-17 18:31:27 UTC
Thanks for your help :)
瀏覽: 4422   回覆: 1
Watering program
Maciej Karpinski
更新時間 2020-05-18 01:01:57 UTC
瀏覽: 4475   回覆: 1
Pixie sync Sprite
Sebastian Diaz
更新時間 2020-05-19 02:50:59 UTC
Thanks you Sebastian
瀏覽: 4801   回覆: 1
Kobus Marneweck
更新時間 2020-05-19 03:33:33 UTC
瀏覽: 4520   回覆: 1
Best settings for garden
Alexandre Morin
更新時間 2020-05-20 11:01:20 UTC
thanks
瀏覽: 4989   回覆: 2
Roman Prochazka
更新時間 2020-05-22 07:55:46 UTC
Many thanks for early answer
Best Regards
Roman
瀏覽: 4725   回覆: 2
Wayne Richards
更新時間 2020-05-23 16:07:26 UTC
瀏覽: 4451   回覆: 1
Rearranging zones?
Kurt H
更新時間 2020-05-23 19:17:20 UTC
瀏覽: 4749   回覆: 1
Pressure compensated drip hose
Simon Clark
更新時間 2020-05-24 17:22:21 UTC
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
瀏覽: 4603   回覆: 0
Chris Graham
更新時間 2020-05-24 20:37:39 UTC
瀏覽: 4762   回覆: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
更新時間 2020-05-24 20:43:23 UTC
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
瀏覽: 4802   回覆: 1
更新時間 2020-05-25 16:08:09 UTC
瀏覽: 4441   回覆: 1
Web interface
Emanuele Floridia
更新時間 2020-05-27 16:58:10 UTC
瀏覽: 4512   回覆: 1
Delay between zones
Nicholas Lydakis
更新時間 2020-05-28 15:39:00 UTC
瀏覽: 4278   回覆: 1
baijuviswam
更新時間 2020-05-28 18:56:02 UTC
瀏覽: 4128   回覆: 1
Jesse For
更新時間 2020-05-29 08:33:36 UTC
瀏覽: 4174   回覆: 1
Missing Whisperer
guags99
更新時間 2020-05-29 18:11:36 UTC
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
瀏覽: 4290   回覆: 1
Smart things?
S D
更新時間 2020-06-01 23:14:05 UTC
瀏覽: 3866   回覆: 0
