Nigel Briggs
更新時間 2025-01-15 10:05:07 UTC
Why ?
瀏覽: 2857   回覆: 1
Pixie - Z1
Steve Inwood
更新時間 2025-01-16 10:10:53 UTC
瀏覽: 2120   回覆: 1
Netro offline
Brett Gardner
更新時間 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
瀏覽: 2245   回覆: 1
W4MSolutions
更新時間 2025-01-23 17:32:49 UTC
瀏覽: 2246   回覆: 1
Discount
darla
更新時間 2025-01-30 20:05:17 UTC
Darla Carpenter
瀏覽: 2119   回覆: 1
Door came off the unit
Michael Riley
更新時間 2025-02-19 19:52:51 UTC
瀏覽: 1909   回覆: 1
Matt
更新時間 2025-04-08 16:25:11 UTC
瀏覽: 1524   回覆: 1
Riego
Felipe Martinez Cuadrado
更新時間 2024-08-16 21:16:23 UTC
He instalado el programador y de vez en cuando salta una de las zonas
瀏覽: 3018   回覆: 1
Server Down 4/27/25?
更新時間 2025-04-27 19:38:18 UTC
瀏覽: 1568   回覆: 5
Whisperer 2
Stephen Brewer
更新時間 2025-04-24 13:43:01 UTC
Steve
瀏覽: 1423   回覆: 1
Garden Bib
Grant Sullivan
更新時間 2025-04-22 22:01:02 UTC
瀏覽: 1454   回覆: 1
Andrea DS
更新時間 2025-04-22 12:33:21 UTC
瀏覽: 1510   回覆: 1
24 hrs
Eric Jonsson
更新時間 2025-04-19 08:19:24 UTC
瀏覽: 1529   回覆: 1
Google Home Assistant
Eric Jonsson
更新時間 2025-04-19 07:46:16 UTC
Eric
瀏覽: 1510   回覆: 1
sdt_babel
更新時間 2025-04-08 17:57:42 UTC
瀏覽: 1562   回覆: 1
Dutch language improvement
Perry en Louise Mevissen
更新時間 2025-03-22 08:54:24 UTC
Kind regards,
Perry
瀏覽: 1678   回覆: 1
Water transfer during rain
mark spencer
更新時間 2025-03-12 02:34:42 UTC
Is there a way?
瀏覽: 1695   回覆: 1
Tiempo de riego
Doyle Farm
更新時間 2025-03-16 17:30:27 UTC
Gracias Marcelo
瀏覽: 1665   回覆: 1
Greenhouse
更新時間 2025-03-22 08:43:22 UTC
One of our sectors runs inside a greenhouse now. Apart from soil type and sprinkler head type, does anyone have advice how to optimise sector settings for this situation? I feel the influence of sun and normal outdoor temperature is different, and rain is completely absent in this sector.
May I suggest to add some sector setting that it is inside a greenhouse?
Perry
瀏覽: 1651   回覆: 1
New Whispere
更新時間 2025-03-31 21:05:02 UTC
What should I do ?
瀏覽: 1574   回覆: 1
