Protecting whisperer from dog
更新時間 2025-05-09 17:54:44 UTC
瀏覽: 1275   回覆: 0
Whisperer 2 temperature?
Brett Rabe
更新時間 2025-05-09 19:07:46 UTC
Thoughts?
瀏覽: 1416   回覆: 1
Will not connect
Rick VanHooser
更新時間 2025-05-10 16:15:01 UTC
瀏覽: 1435   回覆: 2
Kata Cserni
更新時間 2025-05-13 15:32:11 UTC
  1. How can I set an irrigation schedule without WiFi? I have a rental house that is not occupied ( no Internet service) , but I would like to create an irrigation schedule. I app allows me to connect for test run, but not to set new schedule.
瀏覽: 1392   回覆: 1
Panda88
更新時間 2025-05-15 18:20:45 UTC
瀏覽: 1356   回覆: 1
Paolo S
更新時間 2025-05-15 20:41:08 UTC
How can I do?
瀏覽: 1394   回覆: 1
Mikael Hammarin
更新時間 2025-05-26 17:18:52 UTC
Suggestion:
瀏覽: 1237   回覆: 1
Contrôler problem
Alain Turcotte
更新時間 2025-06-06 09:41:00 UTC
瀏覽: 953   回覆: 2
Dropped wifi (2.4 Gz)
C Hill
更新時間 2025-06-06 02:10:45 UTC
瀏覽: 927   回覆: 1
Alexa with two Pizie
Stefano Giorgi
更新時間 2025-06-03 16:11:11 UTC
How can I fix this issue?
瀏覽: 1130   回覆: 1
Water consumption
cwo
更新時間 2025-06-01 19:51:34 UTC
瀏覽: 1116   回覆: 1
Whisperer 2 Dead
更新時間 2025-05-27 23:06:05 UTC
瀏覽: 1270   回覆: 2
How do I change schedule
George S
更新時間 2025-05-27 21:37:14 UTC
瀏覽: 1210   回覆: 1
New Sprite Owner
Bryant Bustamante
更新時間 2025-05-26 22:46:01 UTC
瀏覽: 1410   回覆: 1
Smart Zones are random
Dave H
更新時間 2025-05-19 15:27:46 UTC
Sprite-12
and/or
瀏覽: 1397   回覆: 1
Whisper Gen 2 update firmware
Phil Middleton
更新時間 2025-05-16 14:28:46 UTC
瀏覽: 1375   回覆: 1
Transformer replacement
zoompj@gmail.com
更新時間 2025-05-18 18:43:54 UTC
I have Netro 6
Please help
瀏覽: 1349   回覆: 1
Minh Thu Nguyen
更新時間 2025-05-19 08:42:52 UTC
Dear Netro Support Team,
Best regards,
Minh Thu, Nguyen
瀏覽: 1375   回覆: 1
Refurbished netro controller
drylake
更新時間 2025-05-23 23:37:47 UTC
瀏覽: 1208   回覆: 1
Battery Issue - Netro Stream
K L
更新時間 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
瀏覽: 1241   回覆: 1
