Reset, but still not connecting
lorenzo s
更新時間 2024-12-19 23:36:08 UTC
Please help. I'll provide a reward for getting my N-12 to work.
lss
瀏覽: 2973   回覆: 1
Sprite went offline
dkoford@gmail.com
更新時間 2024-12-18 02:30:29 UTC
瀏覽: 2398   回覆: 1
Changing ownership
Andrew Hopkins
更新時間 2024-12-16 01:39:48 UTC
Andrew
瀏覽: 2483   回覆: 1
Discrepancia APP y WEB
JM del Amo
更新時間 2024-09-07 13:06:53 UTC
瀏覽: 2874   回覆: 1
How do I?
Rockhead413
更新時間 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
瀏覽: 2646   回覆: 1
Schedules
jonathansalina
更新時間 2024-09-28 11:11:52 UTC
瀏覽: 2703   回覆: 1
Zone 1 not watering
11807GFT
更新時間 2024-09-24 23:25:59 UTC
瀏覽: 2770   回覆: 1
Thomas Murphy
更新時間 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
瀏覽: 2781   回覆: 1
Sensor
Kathleen Hamilton
更新時間 2024-09-11 19:43:50 UTC
瀏覽: 2902   回覆: 1
Smart watering not working
更新時間 2024-09-10 16:17:51 UTC
瀏覽: 2849   回覆: 1
Broken whisperer sensor
Jesús López
更新時間 2024-09-09 16:19:33 UTC
Hi everyone!
瀏覽: 3004   回覆: 2
Pierluigi Cilli
更新時間 2024-09-08 07:29:59 UTC
瀏覽: 2909   回覆: 1
Ac adaptor
Cisco -
更新時間 2024-08-24 21:45:58 UTC
瀏覽: 2863   回覆: 1
Van Klaveren Patrick
更新時間 2024-08-15 10:04:53 UTC
瀏覽: 2962   回覆: 1
1 valve works, two don't
Phil Rubin
更新時間 2024-08-17 21:52:30 UTC
瀏覽: 3044   回覆: 1
problematiche app
Giampaolo Mariani
更新時間 2024-08-20 08:16:25 UTC
瀏覽: 3051   回覆: 1
Wunderground
PPL
更新時間 2024-09-02 17:42:25 UTC
瀏覽: 2853   回覆: 1
Tie the irrigation of two lines on the same garden
Francesco
更新時間 2024-09-04 07:59:17 UTC
I have two irrigation lines on the same garden, is there any setting that would allow these two areas to be “tied together” such that they irrigate on the same day (session)? (Obviously first one line and then the other).
瀏覽: 2983   回覆: 1
1 zone not watering
cowlo@xtra.co.nz
更新時間 2024-10-01 01:41:13 UTC
瀏覽: 2861   回覆: 1
Replace controller
paul.robinson@bigbend.net
更新時間 2024-08-24 22:53:15 UTC
瀏覽: 2906   回覆: 1
