Watering time
Andrew Gor
更新時間 2025-07-23 14:36:45 UTC
I added the Netro whisperer 2 soil sensor to my ficus pot. The sensor gives me contradictory messages. It says that next watering should be in one week but every night it sends a notification to 'water the ficus sensor's. What should I do?
瀏覽: 588   回覆: 1
Spark not working – won’t start valves despite all attempts
Stefano
更新時間 2025-07-23 06:55:23 UTC
Hi everyone,
I’ve been using a Netro Spark (8-zone model) for some time, but recently it stopped working properly.
The controller connects to Wi-Fi and appears online in the app, but when I try to start any valve (manually or via schedule), it says “communicating” and nothing happens.
  • Restarted the Spark multiple times
  • Performed a full reset (12 seconds on RST button)
  • Re-added the device in the app
  • Tried to trigger irrigation manually from both the app and the controller
  • Confirmed that the system works when I open the valves manually from the controller
  • Tried different power supplies
  • Connected to a mobile hotspot instead of my home Wi-Fi (same result)
  • Updated the firmware to the latest version (v3.3.0)
  • Purchased a brand new Spark controller and tested it — same exact issue
At this point, it looks like the issue is not hardware or network-related.
Could it be a firmware bug or a server-side problem?
Any help would be greatly appreciated!
Thanks in advance,
Stefano Mauri
瀏覽: 584   回覆: 1
Issue with Netro Spark
Fabrice GOUFFRAN
更新時間 2025-07-23 06:34:33 UTC
瀏覽: 579   回覆: 1
Change zone order
Matt Ward
更新時間 2025-07-22 00:43:18 UTC
瀏覽: 602   回覆: 1
Stefano
更新時間 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
瀏覽: 617   回覆: 1
Whisperer low battery alert
Jesus Sanguinetti
更新時間 2025-07-19 15:24:34 UTC
瀏覽: 673   回覆: 1
Pause
Tamgar chan
更新時間 2025-07-19 10:59:15 UTC
瀏覽: 671   回覆: 1
Franck FONTANEL
更新時間 2025-07-18 19:49:49 UTC
I don’t know why ?
瀏覽: 670   回覆: 1
Daniele Fuccio
更新時間 2025-07-18 17:17:18 UTC
What could the issue be?
Thank you in advance
瀏覽: 683   回覆: 1
Door came off the unit
Michael Riley
更新時間 2025-02-19 19:52:51 UTC
瀏覽: 1916   回覆: 1
Changing ownership
Andrew Hopkins
更新時間 2024-12-16 01:39:48 UTC
Andrew
瀏覽: 2488   回覆: 1
Discount
darla
更新時間 2025-01-30 20:05:17 UTC
Darla Carpenter
瀏覽: 2122   回覆: 1
W4MSolutions
更新時間 2025-01-23 17:32:49 UTC
瀏覽: 2249   回覆: 1
Netro offline
Brett Gardner
更新時間 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
瀏覽: 2249   回覆: 1
Pixie - Z1
Steve Inwood
更新時間 2025-01-16 10:10:53 UTC
瀏覽: 2123   回覆: 1
Nigel Briggs
更新時間 2025-01-15 10:05:07 UTC
Why ?
瀏覽: 2865   回覆: 1
Netro Spark problem
Russ McEvoy
更新時間 2025-01-11 17:12:27 UTC
This morning my 16 zone Spark unit was showing a red LED.
The app said it was online but when I tried to manually water a zone, it just said "connecting" for the duration with nothing happening outside.
Our wifi was running as normal and the room with the controller in had a good signal.
Unplugging and plugging back in solved the problem but it doesn't leave me with much confidence of the unit if it's going to do this at a critical time of year without being noticed.
Is there a reliability issue with the latest firmware?
瀏覽: 2390   回覆: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
更新時間 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
瀏覽: 2165   回覆: 1
Sprite went offline
dkoford@gmail.com
更新時間 2024-12-18 02:30:29 UTC
瀏覽: 2408   回覆: 1
Reset, but still not connecting
lorenzo s
更新時間 2024-12-19 23:36:08 UTC
Please help. I'll provide a reward for getting my N-12 to work.
lss
瀏覽: 2978   回覆: 1
