Andrea DS
更新時間 2024-11-27 21:01:38 UTC
瀏覽: 2317   回覆: 1
Carolyn Simmons
更新時間 2024-12-01 20:53:00 UTC
瀏覽: 2331   回覆: 1
Sprite / Spark and Flume
Bruce P
更新時間 2024-12-12 22:28:13 UTC
Thinking of scenarios like:
瀏覽: 2290   回覆: 1
Changing ownership
Andrew Hopkins
更新時間 2024-12-16 01:38:57 UTC
Andrew
瀏覽: 2331   回覆: 1
Changing ownership
Andrew Hopkins
更新時間 2024-12-16 01:39:48 UTC
Andrew
瀏覽: 2488   回覆: 1
Sprite went offline
dkoford@gmail.com
更新時間 2024-12-18 02:30:29 UTC
瀏覽: 2408   回覆: 1
Reset, but still not connecting
lorenzo s
更新時間 2024-12-19 23:36:08 UTC
Please help. I'll provide a reward for getting my N-12 to work.
lss
瀏覽: 2978   回覆: 1
Random Start
Mario Hardy
更新時間 2024-12-23 12:56:07 UTC
瀏覽: 2241   回覆: 1
John BAIMAY
更新時間 2024-12-26 11:35:25 UTC
Regards.
瀏覽: 2274   回覆: 1
Zone photo
Russ McEvoy
更新時間 2024-12-28 11:29:31 UTC
Can someone help please?
瀏覽: 2249   回覆: 1
Trevor Pfeiffer
更新時間 2024-12-26 20:05:12 UTC
Trevor Pfeiffer
瀏覽: 2257   回覆: 1
Fat Cut
更新時間 2024-12-29 07:11:04 UTC
瀏覽: 2416   回覆: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
更新時間 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
瀏覽: 2165   回覆: 1
Netro Spark problem
Russ McEvoy
更新時間 2025-01-11 17:12:27 UTC
This morning my 16 zone Spark unit was showing a red LED.
The app said it was online but when I tried to manually water a zone, it just said "connecting" for the duration with nothing happening outside.
Our wifi was running as normal and the room with the controller in had a good signal.
Unplugging and plugging back in solved the problem but it doesn't leave me with much confidence of the unit if it's going to do this at a critical time of year without being noticed.
Is there a reliability issue with the latest firmware?
瀏覽: 2390   回覆: 1
Nigel Briggs
更新時間 2025-01-15 10:05:07 UTC
Why ?
瀏覽: 2865   回覆: 1
Pixie - Z1
Steve Inwood
更新時間 2025-01-16 10:10:53 UTC
瀏覽: 2123   回覆: 1
Netro offline
Brett Gardner
更新時間 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
瀏覽: 2249   回覆: 1
W4MSolutions
更新時間 2025-01-23 17:32:49 UTC
瀏覽: 2249   回覆: 1
Discount
darla
更新時間 2025-01-30 20:05:17 UTC
Darla Carpenter
瀏覽: 2122   回覆: 1
Door came off the unit
Michael Riley
更新時間 2025-02-19 19:52:51 UTC
瀏覽: 1916   回覆: 1
