Batteria pixie
Max64
更新時間 2025-05-02 08:32:19 UTC
瀏覽: 1478   回覆: 1
Pixie Offline
mprtjd
更新時間 2025-05-03 15:33:15 UTC
瀏覽: 1524   回覆: 1
How to create a 2nd user
bdelariva
更新時間 2025-05-04 13:16:18 UTC
瀏覽: 1625   回覆: 1
Kai Nicholson
更新時間 2025-05-04 14:12:08 UTC
瀏覽: 1749   回覆: 1
Scott Flanigan
更新時間 2025-05-04 20:09:46 UTC
瀏覽: 1500   回覆: 1
dillonhueser
更新時間 2025-05-07 19:04:41 UTC
瀏覽: 1480   回覆: 1
更新時間 2025-05-09 12:29:14 UTC
瀏覽: 1578   回覆: 3
Zones not turning on
Neil ONeill
更新時間 2025-05-09 12:41:28 UTC
瀏覽: 1519   回覆: 1
Protecting whisperer from dog
更新時間 2025-05-09 17:54:44 UTC
瀏覽: 1548   回覆: 0
Whisperer 2 temperature?
Brett Rabe
更新時間 2025-05-09 19:07:46 UTC
Thoughts?
瀏覽: 1557   回覆: 1
Will not connect
Rick VanHooser
更新時間 2025-05-10 16:15:01 UTC
瀏覽: 1710   回覆: 2
Kata Cserni
更新時間 2025-05-13 15:32:11 UTC
  1. How can I set an irrigation schedule without WiFi? I have a rental house that is not occupied ( no Internet service) , but I would like to create an irrigation schedule. I app allows me to connect for test run, but not to set new schedule.
瀏覽: 1534   回覆: 1
Panda88
更新時間 2025-05-15 18:20:45 UTC
瀏覽: 1364   回覆: 1
Paolo S
更新時間 2025-05-15 20:41:08 UTC
How can I do?
瀏覽: 1402   回覆: 1
更新時間 2025-05-16 12:40:39 UTC
瀏覽: 1473   回覆: 1
Whisper Gen 2 update firmware
Phil Middleton
更新時間 2025-05-16 14:28:46 UTC
瀏覽: 1383   回覆: 1
Transformer replacement
zoompj@gmail.com
更新時間 2025-05-18 18:43:54 UTC
I have Netro 6
Please help
瀏覽: 1496   回覆: 1
Minh Thu Nguyen
更新時間 2025-05-19 08:42:52 UTC
Dear Netro Support Team,
Best regards,
Minh Thu, Nguyen
瀏覽: 1520   回覆: 1
Smart Zones are random
Dave H
更新時間 2025-05-19 15:27:46 UTC
Sprite-12
and/or
瀏覽: 1403   回覆: 1
overwatering
更新時間 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
瀏覽: 1402   回覆: 2
