Zones run at the same time
Rich Christenson
更新時間 2019-08-15 11:05:09 UTC
瀏覽: 4978   回覆: 3
Whisperers firmware update
更新時間 2019-08-15 16:25:53 UTC
When is it going to be released?
瀏覽: 4358   回覆: 0
更新時間 2019-08-16 02:54:33 UTC
瀏覽: 4811   回覆: 1
Alexa skill
Tony D.
更新時間 2019-08-16 23:42:33 UTC
What do I need to search for?
瀏覽: 4642   回覆: 1
Rainfall correction
cjmulk2
更新時間 2019-08-17 03:15:16 UTC
Feature request: On the discover screen, please allow rainfall correction further back than yesterday and allow setting the correct rainfall amount to zero. (Lowest it goes currently is 0.1).
瀏覽: 4545   回覆: 1
Feature Request: API
cjmulk2
更新時間 2019-08-17 03:18:34 UTC
瀏覽: 4977   回覆: 3
Drain
Moe
更新時間 2019-08-17 23:31:13 UTC
瀏覽: 4654   回覆: 1
Why water twice a day?
Ron White
更新時間 2019-08-19 19:05:12 UTC
瀏覽: 4618   回覆: 2
Internet connection problems
danadcock
更新時間 2019-08-20 14:07:11 UTC
I have had a lot of trouble with losing netro's connection with internet. My old router failed so I replaced it with an expensive mesh wifi system which provides wonderful service to everything I have tried to connect except my Netro! I have now discovered that it will not work with anything but 2.4 GHz wifi. The new wifi does not provide 2.4 connection. Is there a workaround for this? Or do I have to throw out my new state-of-the-art $400 5 GHz wifi to get my somewhat obsolete $100 Netro to work?
瀏覽: 5045   回覆: 2
Smart watering once a week?
Andrea D.
更新時間 2019-08-22 05:51:16 UTC
Hello there,
I'm new to netro and I tried to setup smart watering but the data I provided it will do it just once a week.
How is it possible? Is it safe to water just once a week?
瀏覽: 4486   回覆: 1
Weather Provider
Martin Müller-Zantop
更新時間 2019-08-22 10:57:44 UTC
Can you please explain to me the big difference of the next watering days using different weather providers? As you can see in my print screens the data of temperature and humidity are nearly the same. With one provider next watering cycle will be in 2 days and with another in 11 days.
Thank you for your comments
Martin
瀏覽: 5205   回覆: 2
Yellow triangle with ! Inside
Michael Pakalolo
更新時間 2019-08-24 16:15:54 UTC
What does the yellow triangle with the ! mean next to the schedule
瀏覽: 4610   回覆: 1
How does a whisper sensor work with a drip system?
L F
更新時間 2019-08-25 23:46:33 UTC
I have a couple whisper sensors monitoring my lawn and drip system.   I understand how they can monitor the soil in my lawn but I’m wonder how the whisper works on my drip system as it doesn’t see the moisture that’s added to the soil(the emitter isolates the water to the plant) or the rate the plants use it like the one in the lawn does.  I’m assuming it’s just estimating like the Netro would on it’s own.  Is there much value to using a whisper on a drip zone?
瀏覽: 4654   回覆: 1
watering sequence
Gérard GALBOIS
更新時間 2019-08-26 18:23:46 UTC
It is unfortunatly not possible to change  in which ordre the watering will act.
for exemple I need to water zone 5 after zone 7 because zone 7 is at a higher level than the electro valve and remaining water pressure, after watering is stopped,  is to strong and prevents the valve to close . by watering supplemantary  zone 5 which is lower the pressure diminishes ans the valve of zone 7 closes..
瀏覽: 4597   回覆: 1
System went basqerk?
Ron White
更新時間 2019-08-27 01:21:18 UTC
瀏覽: 4740   回覆: 2
Power Transformer
DeanH
更新時間 2019-09-04 02:31:34 UTC
I have my controller in my garage here in the desert.  The transformer seems very hot to the touch.  Is this a problem??
瀏覽: 5699   回覆: 3
New Whisper not reporting
更新時間 2019-09-04 17:11:14 UTC
I recently ordered a second whisper and installed it the same way as the first one I received (which is still working fine)  It connects just fine and I can even change the color of the LED for a while.  But it reported only once to the app and that was it.  I have tried reconnecting it to WiFi, I even deleted it in the app and reinstalled it with no success.  After the initial connection it seems to just stop working.
瀏覽: 5018   回覆: 1
Ron White
更新時間 2019-09-04 16:44:17 UTC
瀏覽: 4766   回覆: 1
Manual run time screen
Rich Christenson
更新時間 2019-09-06 10:25:49 UTC
瀏覽: 4924   回覆: 1
Windows 10 APP or web page
Emanuel Di Giusto
更新時間 2019-09-06 19:46:57 UTC
瀏覽: 4596   回覆: 1
