Tony D.
更新時間 2019-09-09 12:57:04 UTC
瀏覽: 4906   回覆: 1
Feature request
Tony D.
更新時間 2019-09-12 20:32:30 UTC
Tony
瀏覽: 4733   回覆: 1
更新時間 2019-09-17 12:12:15 UTC
瀏覽: 4815   回覆: 1
Unit measurements
Homestead One
更新時間 2019-09-17 20:29:09 UTC
瀏覽: 4507   回覆: 1
Schedule setup
Rich Christenson
更新時間 2019-09-21 14:51:31 UTC
瀏覽: 4529   回覆: 1
Whisperer seems wrong
Tim Foster
更新時間 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
瀏覽: 4705   回覆: 1
Tony D.
更新時間 2019-09-24 21:08:17 UTC
Hello everybody,
瀏覽: 4752   回覆: 1
Ip address
Kris Y
更新時間 2019-09-25 20:13:08 UTC
瀏覽: 4575   回覆: 1
Solid white light after install - HELP
Carlos Oliveira
更新時間 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
瀏覽: 4747   回覆: 1
Cold winter season and whisperer ?
Yves Desrosiers
更新時間 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
瀏覽: 6017   回覆: 3
hanz.blatt@gmail.com
更新時間 2019-09-29 13:59:02 UTC
瀏覽: 8015   回覆: 2
Nguyễn Vinh
更新時間 2019-09-30 06:46:55 UTC
瀏覽: 4746   回覆: 2
sqwu
更新時間 2019-09-30 13:51:09 UTC
瀏覽: 4648   回覆: 1
Installation Direct to pump
Tim Foster
更新時間 2019-10-03 11:23:32 UTC
I have the following:
瀏覽: 5015   回覆: 2
Weird watering plan
Manuel Roca
更新時間 2019-10-12 11:34:00 UTC
瀏覽: 4456   回覆: 1
Brian Hobbs
更新時間 2019-10-15 01:58:49 UTC
瀏覽: 4521   回覆: 1
Sangjin Lee
更新時間 2019-10-17 03:41:11 UTC
瀏覽: 4717   回覆: 1
What about blowout?
Burghardi
更新時間 2019-10-18 02:06:15 UTC
Why doesn’t this one?
瀏覽: 4625   回覆: 2
Riego netro para tepes
Manuel C
更新時間 2019-10-23 09:36:27 UTC
Hola,
瀏覽: 6360   回覆: 1
Daylight savings
Craig Neidle
更新時間 2019-11-13 18:34:27 UTC
Haow can i change this?
瀏覽: 4785   回覆: 1
