Random Manual Start
Mario Hardy
更新時間 2023-07-13 04:52:51 UTC
How to make this stop???
瀏覽: 3729   回覆: 0
Random Manual Start
Mario Hardy
更新時間 2023-07-13 04:53:04 UTC
瀏覽: 3925   回覆: 1
sellet
更新時間 2023-07-13 16:20:23 UTC
瀏覽: 3714   回覆: 1
Problème de localisation
Yoann Lienard
更新時間 2023-07-16 10:54:55 UTC
Bonjour ,
Comment faire ?
Merci de votre réponse.
Yoann
瀏覽: 3586   回覆: 1
Watering even when it's wet
Jure
更新時間 2023-07-16 14:14:17 UTC
瀏覽: 3942   回覆: 1
Weather underground
Dion Friedt
更新時間 2023-07-17 03:09:10 UTC
瀏覽: 3552   回覆: 1
Preferences about time
Paolo Vecchi
更新時間 2023-07-17 07:41:39 UTC
瀏覽: 3623   回覆: 1
Andrea Vecchia
更新時間 2023-07-17 14:34:51 UTC
瀏覽: 3617   回覆: 1
Not calculating for ecomode?
Melissa N
更新時間 2023-07-20 05:42:48 UTC
How can I fix this?
瀏覽: 3448   回覆: 1
ALGORITHM FLOW RATE
Javier NM
更新時間 2023-07-20 07:08:54 UTC
瀏覽: 3968   回覆: 1
Mirko Zen
更新時間 2023-07-21 09:35:33 UTC
瀏覽: 3457   回覆: 1
更新時間 2023-07-24 00:54:03 UTC
瀏覽: 3893   回覆: 1
misterhoff
更新時間 2023-07-25 03:11:25 UTC
瀏覽: 3508   回覆: 0
Feature request update
更新時間 2023-07-25 06:11:19 UTC
瀏覽: 3848   回覆: 1
Netro - Stopped Working and won’t power up
John Loethen
更新時間 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
瀏覽: 3633   回覆: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
更新時間 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
瀏覽: 4056   回覆: 2
Netro phone app won't open
Christopher Scarborough
更新時間 2023-07-30 23:32:37 UTC
瀏覽: 3585   回覆: 1
Tim Quach
更新時間 2023-08-01 08:02:49 UTC
瀏覽: 3572   回覆: 1
Atif Siddiqui
更新時間 2023-08-02 04:51:58 UTC
瀏覽: 3612   回覆: 1
Using Bootlace ferrules.
Bob Howard
更新時間 2023-08-03 06:36:09 UTC
I'd like to use bootlace ferrules for all the wiring to the sprite as shown in your installation video (power connection). I'm using 0.5mm² x 7 core cable and 0.5mm² bootlaces and the unit won't grip them. I've tried other sizes with the same result. What size ferrule is required?
瀏覽: 4422   回覆: 1
