Beau Cook
更新時間 2023-06-12 23:10:58 UTC
瀏覽: 3542   回覆: 1
Delay settings
Roberto Pirovano
更新時間 2023-06-13 09:15:35 UTC
瀏覽: 3761   回覆: 1
Calibrating sprinkler output
SonDeMar
更新時間 2023-06-13 15:16:54 UTC
瀏覽: 3624   回覆: 1
No notifications
Khalid Mousa
更新時間 2023-06-14 03:25:18 UTC
瀏覽: 3852   回覆: 1
Pixie-Z1-H - How to install?
kernel
更新時間 2023-06-14 15:54:05 UTC
  • I have received a new Pixie-Z1 and a hub
  • Downloaded the Netro iOS App from the UK app store
  • In the App I added the hub connecting through Bluetooth and configuring WiFi access for the hub
  • Hub shows constant green light
Now how can I add the Pixie-Z1 hose faucet to my account? The App only shows the option for the Pixie-1, which doesn't work because the Pixie-Z1 uses the Zigbee connection, not WiFi.
瀏覽: 4878   回覆: 1
zoe
更新時間 2023-06-15 00:40:38 UTC
Linda Lundgren
瀏覽: 3683   回覆: 1
Rainy day shut off
更新時間 2023-06-16 13:18:25 UTC
瀏覽: 3840   回覆: 1
Zone doesn't stay on
Brent S
更新時間 2023-06-18 02:05:28 UTC
Hi just installed a sprite 6. I can here zone turn on then immediately turns off but the timer is still running on the app. I can hear the water stop and start in each zone ; the app thinks it's watering but the valve closes. Same for all zones
Thansk
瀏覽: 3911   回覆: 1
Luis T
更新時間 2023-06-18 15:30:17 UTC
Any comments are welcome.
瀏覽: 4949   回覆: 3
更新時間 2023-06-19 09:25:40 UTC
瀏覽: 3978   回覆: 2
Disconnessione
Carlo Capraro
更新時間 2023-06-19 12:11:17 UTC
Grazie a tutti
瀏覽: 3460   回覆: 1
Massimo Oldrini
更新時間 2023-06-20 07:57:16 UTC
Buongiorno,
L’apparato va sostituito?
瀏覽: 3609   回覆: 2
Start-end time not working
Fabio Silvestri
更新時間 2023-06-21 05:20:31 UTC
瀏覽: 3882   回覆: 3
Zones not watering
joefil
更新時間 2023-06-22 16:54:38 UTC
Your help is appreciated
瀏覽: 3645   回覆: 1
Ralph G
更新時間 2023-06-23 18:56:48 UTC
瀏覽: 3800   回覆: 1
120 Sweet Bailey
更新時間 2023-06-23 23:14:09 UTC
瀏覽: 3551   回覆: 1
Malfunzionamento durata irrigazione
MarcoPolinari
更新時間 2023-06-25 21:45:29 UTC
Buonasera,
quando avvio l'irrigazione, sia in manuale che in automatico, la centralina attiva per circa 2 secondi la zona e la pompa e poi si spegne, mentre  dal APP sembra che proceda tutto regolarmente.
瀏覽: 3886   回覆: 1
更新時間 2023-06-26 12:06:15 UTC
  1.  it's raining or
瀏覽: 3831   回覆: 1
更新時間 2023-06-27 08:48:51 UTC
瀏覽: 3831   回覆: 1
Connection issue
Federica Musmanno
更新時間 2023-06-27 12:16:35 UTC
瀏覽: 3584   回覆: 1
