connecting to wifi..
Phani Gade
更新時間 2018-10-15 17:20:42 UTC
瀏覽: 4602   回覆: 0
Moberley
moberleyj@verizon.net
更新時間 2018-10-17 16:59:29 UTC
瀏覽: 4942   回覆: 1
George Zraick
更新時間 2018-10-27 20:05:15 UTC
瀏覽: 4946   回覆: 1
Service
Matt Lasser
更新時間 2018-10-31 16:01:30 UTC
瀏覽: 4970   回覆: 1
Skipping skipped?
livingwater71
更新時間 2018-10-31 16:11:03 UTC
瀏覽: 4778   回覆: 1
EPA rebate status?
Joshua Berk
更新時間 2018-11-04 07:39:58 UTC
Hi I was wondering if we could get an update on where Netro is with an EPA rebate? We're aware Netro has applied, but any word or ETA on getting certification for rebates?  Thank you
瀏覽: 5462   回覆: 3
Water pump shutting off
Ryan Cochran
更新時間 2018-11-26 02:32:24 UTC
瀏覽: 5030   回覆: 1
Rebekah H
更新時間 2018-11-28 04:23:43 UTC
瀏覽: 4997   回覆: 1
Sangjin Lee
更新時間 2018-12-15 18:56:48 UTC
Thanks in advance!
瀏覽: 8004   回覆: 1
Leak detection
Joshua Berk
更新時間 2019-01-03 15:27:07 UTC
Rachio has a new leak detection device you can install on the pipe that talks to the controller letting it know if there's water flow that shouldn't be happening. Do you guys have plans to do anything like this? Would absolutely be interested in it!
瀏覽: 4865   回覆: 0
St. Augustine
Spencer Vaughn
更新時間 2019-01-10 03:15:53 UTC
瀏覽: 6730   回覆: 2
Tim Cox
更新時間 2019-02-02 01:35:59 UTC
瀏覽: 5083   回覆: 3
Nathan Anderson
更新時間 2019-02-13 03:53:31 UTC
瀏覽: 5045   回覆: 1
Scot and Michelle Cowan
更新時間 2019-03-03 17:04:51 UTC
瀏覽: 5412   回覆: 1
Instructions about Replacing Toro System
更新時間 2019-03-20 08:07:29 UTC
Replacing Toro system
This page lists some instructions about replacing the common types of Toro system with Netro smart watering controller.
Example 1:
Toro model gk212-04
1. Connect the 2 white wires to the C slots, one on the left and the other on the right which is now occupied by a red one.
2. Move the red wire(currently on C slot) to M slot because it is for your master valve.
3. The last step is to connect the power then you should be good to go.
Example 2:
Toro IC 8.
The first slot of your current controller is master valve which should be connected  to "M" slot of Netro. The two wires in the second slot are common wires should be connected to the 'C' slot of Netro. The last step is to connect the power then you should be good to go.
Example 3:
Toro Model 53765 6 zones
The red and white wires are the commons wires and should go to the two "C" slots in Netro Sprite controller. You do not need to connect the gray and black wires as they are the power wires for the old controller.
瀏覽: 6778   回覆: 0
更新時間 2019-03-20 08:03:05 UTC
Replacing old system
Example 1:
I check the pictures.
OLD                 Sprite
COM                any C slot
1                     1
2                     2
3                     3
4                     4
Example 2:
Example 3:
Example 4:
Other wires are not needed.
Example 5:
瀏覽: 5383   回覆: 0
Overriding smart waterinh
mvernia
更新時間 2019-03-17 20:46:27 UTC
瀏覽: 4671   回覆: 1
charu
更新時間 2019-03-21 16:27:21 UTC
瀏覽: 4545   回覆: 1
Not able to water
更新時間 2019-03-27 13:18:49 UTC
瀏覽: 5000   回覆: 1
controller firmware
Magnus Swenson
更新時間 2019-03-27 19:55:40 UTC
Does the controller update its own firmware automatically on a specific schedule or you push out when needed?
瀏覽: 5166   回覆: 1
