How do I change schedule
George S
Updated at 2025-05-27 21:37:14 UTC
View: 7848   Answer: 1
New Sprite Owner
Bryant Bustamante
Updated at 2025-05-26 22:46:01 UTC
View: 9620   Answer: 1
Mikael Hammarin
Updated at 2025-05-26 17:18:52 UTC
Suggestion:
View: 9082   Answer: 1
Battery Issue - Netro Stream
K L
Updated at 2025-05-25 03:09:56 UTC
Dear Fellows,
Device Details:
  • Hardware : Netro Stream 1.0
  • Firmware: 1.0.0
Best regards,
Kelvin
View: 9512   Answer: 1
Refurbished netro controller
drylake
Updated at 2025-05-23 23:37:47 UTC
View: 8562   Answer: 1
overwatering
Updated at 2025-05-20 12:55:43 UTC
- Sensor to report every hour
- skip watering if above 60%
- Sensor firmware 2.0.1
View: 9163   Answer: 2
Smart Zones are random
Dave H
Updated at 2025-05-19 15:27:46 UTC
Sprite-12
and/or
View: 9006   Answer: 1
Minh Thu Nguyen
Updated at 2025-05-19 08:42:52 UTC
Dear Netro Support Team,
Best regards,
Minh Thu, Nguyen
View: 9808   Answer: 1
Transformer replacement
zoompj@gmail.com
Updated at 2025-05-18 18:43:54 UTC
I have Netro 6
Please help
View: 9931   Answer: 1
Whisper Gen 2 update firmware
Phil Middleton
Updated at 2025-05-16 14:28:46 UTC
View: 7868   Answer: 1
Updated at 2025-05-16 12:40:39 UTC
View: 9707   Answer: 1
Paolo S
Updated at 2025-05-15 20:41:08 UTC
How can I do?
View: 9119   Answer: 1
Panda88
Updated at 2025-05-15 18:20:45 UTC
View: 8756   Answer: 1
Will not connect
Rick VanHooser
Updated at 2025-05-10 16:15:01 UTC
View: 8713   Answer: 2
Whisperer 2 temperature?
Brett Rabe
Updated at 2025-05-09 19:07:46 UTC
Thoughts?
View: 9078   Answer: 1
Protecting whisperer from dog
Updated at 2025-05-09 17:54:44 UTC
View: 8848   Answer: 0
Zones not turning on
Neil ONeill
Updated at 2025-05-09 12:41:28 UTC
View: 7486   Answer: 1
Updated at 2025-05-09 12:29:14 UTC
View: 7915   Answer: 3
dillonhueser
Updated at 2025-05-07 19:04:41 UTC
View: 7012   Answer: 2
Scott Flanigan
Updated at 2025-05-04 20:09:46 UTC
View: 7126   Answer: 1
