No water comes out when I started my Netro
Fay Hatfield
Updated at 2025-11-09 20:53:57 UTC
Hi everyone, I purchased my Netro about one year and half ago. It used to work normally. It stop working a couple months ago. When I started it, it says watering but no actual water comes out. I did everything the support team told me to do but still nothing happened. I’m desperate, my grass is dying. Someone please assist.
View: 4764   Comment: 3
Zone flexibility
Mike R
Updated at 2025-10-29 01:20:50 UTC
I have a hill that was terraced and replanted. I was told to run the circuit twice a day for 15 minutes for a month. Drip lines. Seems like my system doesn’t have that flexibility. Am i correct?
View: 4255   Answer: 1
Seeding my lawn this week... How do I adjust the "New Plant" option for consistent watering?
Jonathan B.
Updated at 2025-10-20 22:59:45 UTC
Hi... since it's still fairly warm outside, I'd like to have the Zone water every 2 hrs for about 3 minutes just to keep the ground moisture up.
I'm not clear on how to do this?  Anyone?
View: 4476   Answer: 1
Giardino
Nelu Iftime
Updated at 2025-10-20 08:18:25 UTC
Sistemato
View: 5918   Comment: 0
Wind preference for drippers
Troy Robertson
Updated at 2025-10-17 06:46:57 UTC
Hey,
Is it possible to individually choose preferences for wind speed on a zone by zone basis? I've got some zones that are connected to sprayers which I would like to keep on a wind speed cutout and but most zones are on drippers which I would like to water independent of the wind speed.
View: 4381   Answer: 1
Can't login
Updated at 2025-10-13 15:40:38 UTC
This morning we noticed that my Sprite light was flashing. I tried to get into the app and it kept saying network error. I booted the Sprite, I booted my router, and the light is no longer flashing.
But when I try to log into the app now it says network error. I logged into metrohome.com and my Sprite was able to work from naturalhome.com, but I am still not able to log in to the app. I use the same login at netrohome.com as I did with my app.
View: 5267   Comment: 1
App crash
Nick
Updated at 2025-10-12 20:41:50 UTC
The app crashea when I click on a zone on Google pixel 8a. I had to configure them with another phone. Already tried to reinstall the app and clear cache
View: 4558   Answer: 1
L irrigazione non parte
Marco Michelini
Updated at 2025-10-11 15:55:45 UTC
Hi, dopo aver collegato tutto, ho provato a fare un test manuale ma non parte l irrigazione.
Sapete aiutarmi?
View: 4348   Answer: 1
End of Season Shut down
Jayme Buhlman
Updated at 2025-10-10 17:59:16 UTC
Hi, it’s the end of our watering season where I live, the city just shut off the water for the year. Any guidance on what to do in the app to have the system off for until spring?
Is it a good idea to unplug it for the season or no?
View: 4783   Answer: 1
Problem: Spark 16 controller stuck on "in communication"
Corrado
Updated at 2025-10-08 13:48:10 UTC
I'm experiencing a serious issue with my Netro Spark 16 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
The problemm is with the 4g Vodafone/HoMobile provider as yout mentioned in https://netrohome.com/en/forum/posts/4052
I have already asked several time the update for the device, but nobody reply me
i wrote also to Netro support email: support@netrohome.com  --> nobody reply me.
What should i do to have this update?
Please
View: 4278   Answer: 1
Updated at 2025-10-08 13:12:52 UTC
View: 4420   Answer: 2
Password
Ignacio Sánchez
Updated at 2025-09-26 11:38:52 UTC
View: 5056   Answer: 1
Whisperer installation
Davide Chelo
Updated at 2025-09-26 11:38:17 UTC
Hi, I just bought the whisperer 2 and would like to have it as only sensor for the entire garden, however is allowed to have maximum 3 zones for sensor. Is there a way to link all the zones to it? I have 7 zones.
View: 4942   Answer: 1
I want to change wifi network my Netro controller is connected too.
loro
Updated at 2025-09-23 21:27:44 UTC
How do I change the wifi network my Netro controller is connected too? I cannot proceed beyond step 2 from the instructions on the app. I get the message "Please connect to Wi-fi network "Netro_IRC_xxx."  However, the app shows that I am already connected!!
View: 5453   Answer: 1
Info function
Giuseppe
Updated at 2025-09-20 09:48:50 UTC
View: 5568   Answer: 1
Program change Day
Tiziano Pacella
Updated at 2025-09-17 19:04:30 UTC
Someone can help me?I need change the day for one program exists...what is the procedure? Thak you
View: 5477   Answer: 1
Rainbird esp me series
Magnus Swenson
Updated at 2025-09-15 14:38:33 UTC
Can I use the Netro Spark 16 if I use the Rainbird ESP Me? I have 15 active zones.
View: 5765   Answer: 1
Time
Silvano Scotto
Updated at 2025-09-10 23:18:59 UTC
View: 6297   Answer: 1
Centralina non funziona
gsciurba
Updated at 2025-09-09 19:23:32 UTC
Buongiorno,
  • la tensione in uscita è sempre di circa 11 V AC su tutte le uscite;
  • la centralina è stata utilizzata pochissimo, solo con le zone master e 1–2;
  • non sono presenti segni visibili di bruciatura o danni hardware.
Grazie per l’attenzione.
Cordiali saluti,
Giuseppe Sciurba
View: 6255   Answer: 1
Netro spark no work
Fernando Bravo Calatayud
Updated at 2025-09-04 08:25:22 UTC
I've had a Netro Spark 8 working without any problems since last year, but a few days ago it disconnected from the Wi-Fi and stopped working. I tried the reset button as indicated in the instructions, but there's no way to reconnect it. What else can I do? Thank you very much
View: 6703   Answer: 1
