My password
Cliff Howatd
Updated at 2026-05-11 14:08:56 UTC
My password keeps dropping, and I have to re-enter the password every time I want to use my phone to access programs.
View: 2673   Answer: 1
New feature request
Updated at 2026-05-10 19:34:04 UTC
View: 2674   Answer: 1
programs - status sign
Lee Hill
Updated at 2026-05-08 06:45:32 UTC
Developers, can you add some indication to list of programs to see which is enabled, which is not?
Instead of going into each and scroll to the very bottom to check 'enabled'.
I think of either being grayed out or adding a sign, whatever simplest may work.
thank you
View: 2647   Answer: 1
programs - reordering
Lee Hill
Updated at 2026-05-08 06:40:14 UTC
View: 2700   Answer: 1
Notifications sur Android
Cyrille ROBINET
Updated at 2026-05-03 16:14:14 UTC
Bonjour,
J'aimerais avoir de l'aide.
Merci
View: 2763   Answer: 1
Feature Request / Setup Assistance: Apply Rain Skip to User Programs without Smart Scheduling
Alessandro Zannini
Updated at 2026-05-01 16:47:43 UTC
Hello Netro Support Team,
I am a user of the Netro system and I need assistance with my zone configuration.
Currently, I have a specific zone (named "Goccia") set up with a User Program (fixed days and fixed minutes). I do not want the Netro AI to change my watering duration or frequency.
However, I want the system to automatically skip my fixed program if it rains or if rain is predicted.
In my app settings for this zone, I see that "Smart Zone" is currently Disabled. My questions are:
1. If I enable "Smart Zone", will it overwrite my manual minutes and days, or will it only apply the "Rain Skip" feature to my existing User Program?
2. How can I ensure that the system follows my fixed schedule strictly, but still uses weather data to skip cycles during rain?
I want my manual program to be "Weather-aware" without becoming "AI-controlled".
Thank you for your help.
Best regards,
View: 2740   Answer: 1
When Zone 11 is programmed to run but zone 4 runs instead.
Mike
Updated at 2026-04-21 18:10:56 UTC
Zone 4 correctly runs when zone 4 is activated
View: 3277   Answer: 1
Different weather and does not skip rainy days
Leonardo A
Updated at 2026-04-20 06:25:01 UTC
Good morning, if anyone can help me, I have two Netro control units installed 1 km from each other and they give me two different forecasts, both having the same weather portal, one irrigates it even with rainy days, while the other gives me the programming in 20 days.....
View: 3735   Answer: 1
enable switch
Andrew McNaughtan
Updated at 2026-04-19 22:32:06 UTC
I switched the enable switch in the Netro app to disable and now I can't get it to turn back on. The app says "next run not scheduled". When I close the app and reopen it, the switch has moved back to the disabled position. Nothing works, I can't even manually water. The controller has a green light showing and I have tried powering the controller off and back on and it reconnects without an issue but the app will not work.
View: 3339   Answer: 1
Not skipping raining days
Felipe VNunes
Updated at 2026-04-17 23:00:44 UTC
Hi guys,
My Netro system is not skipping watering on rainy days. As shown below, it still watered even though it is configured to skip the previous day, the rainy day itself, and the day after. Any recommendations?
View: 3264   Answer: 1
Multiple locations
paul.robinson@bigbend.net
Updated at 2026-04-12 21:06:55 UTC
View: 3391   Answer: 1
Any way for user to open and replace battery in Whisperer 2?
Updated at 2026-04-09 02:24:02 UTC
Any way for end user to open and replace battery on a whisperer 2?  It is out of warranty.
View: 3453   Answer: 1
Combine 2 zones
Alexis Demosthenous
Updated at 2026-04-07 03:33:14 UTC
Hello everyone,
For my lawn i have 2 watering zones, is there a way to "force" schedule to combine those 2 zones to always follow each other? I dont want to water half my lawn on Monday and the other half on Thursday.
View: 3419   Answer: 2
Peter OBRIEN
Updated at 2026-03-27 00:55:46 UTC
Samsung S25 - unable to pair own WIFI after connection to Netro
View: 3863   Comment: 1
Pixie solar panel
Noam Leshem
Updated at 2026-03-23 14:31:41 UTC
Just i thought. My pixie is connected to a tap that is shaded most of the day. It would be great if the solar panel was removable so it can be placed in a better place with a wire to the pixie.
View: 3719   Comment: 2
Pixie se desconecta
Lino
Updated at 2026-03-22 19:30:16 UTC
Por qué se desconecta después de unos minutos mi unidad Pixie si tiene batería?
View: 3486   Answer: 1
Drip
Tim P
Updated at 2026-03-22 18:23:10 UTC
All the zones work except I do not have any water coming out of the drip heads
View: 3371   Answer: 1
Drip
Tim P
Updated at 2026-03-22 18:03:51 UTC
View: 3424   Answer: 1
Drip
Tim P
Updated at 2026-03-22 18:03:43 UTC
View: 3389   Answer: 1
Adding a 2nd system
Jayden Lockley
Updated at 2026-03-21 07:03:33 UTC
I currently have a Netro Sprite system set up on a bore, I'm only using 9 stations currently but I can't easily add any more stations/wiring to this system.
I can easily access the wiring where I would like to add more stations, am I able to pick up the earth and pump start wires, and add a 2nd sprite or spark controller there?
Or has anyone got any ideas of how I can add more stations without running more wiring back to the master controller?
View: 3733   Answer: 1
