Wrong location detected: Italy address is always converted to Oklahoma, USA
tizzy
Updated at 2026-07-02 10:11:39 UTC
I have a Netro Spark 8 controller installed in Italy.
My address is:
Via Gonfalone 49
73031 Alessano (LE)
Italy
However, Netro always changes my location to:
  • ZIP code: 73032
  • State: OK
  • Country: United States
Because of this, the weather forecast is completely wrong and Smart Watering is using incorrect weather data.
I cannot edit the ZIP code, state or country, either in the Android app or on the web interface.
Could you please help me fix my location or update your geolocation database?
View: 1141   Answer: 1
Netro Smart Settings
caravagg
Updated at 2026-06-30 11:58:32 UTC
netro smart settings, please rank relative seasonal water use from high to low for the different settings: EPA, Boost, New Plant, Deep, Frequent, Regular, ECO
View: 1126   Answer: 1
No water coming from sprinklers of 3 zones
Sukesh Arora
Updated at 2026-06-28 15:31:51 UTC
Although the App says that it is watering a particular zone but no water comes out of the sprinkler heads. What could be causing that?
View: 1164   Answer: 1
Sukesh Arora
Updated at 2026-06-28 15:23:05 UTC
View: 1106   Answer: 1
Netro Skill
ghutch2262
Updated at 2026-06-26 14:52:07 UTC
The netro skill does not stay connected to Alexa.  What is the issue with that?
View: 1201   Answer: 1
How does eco factor work?
Updated at 2026-06-21 16:02:22 UTC
View: 1220   Answer: 1
Nuovo wi fi e luce spenta
Paolo Grippa
Updated at 2026-06-21 08:13:39 UTC
A seguito di nuova installazione wi fi fibra home, il dispositivo mi da luce spenta come se non arrivasse corrente, ma in realtà la corrente arriva. Ho infatti provato a staccare e riattaccare tutto ma la situazione non cambia. Quale può essere il problema?
Es un problema
Alejandro Miguel
Updated at 2026-06-17 20:34:07 UTC
El programador es un verdadero rollo deja de tener conexión no actúa riega cuando le da la gana no lo recomendaría jamas
View: 1697   Comment: 1
Notificaciones
Peter urrielu
Updated at 2026-06-14 07:59:40 UTC
Hola, en la sección de notificaciones de la aplicación, no hay nada, no hay ningún tipo de notificaciones para elegir. Es un problema de la versión de la aplicación o es un problema mío?. Gracias
View: 1512   Answer: 1
Can you add rain sensor to the Spark system? Is there one available?
Devros
Updated at 2026-06-12 00:03:03 UTC
Just wondering if you can add a rain sensor to the Spark system?  If so what brand?
View: 1381   Answer: 1
Più elettro valvole
Enrico Crola
Updated at 2026-06-11 08:07:24 UTC
Come faccio per poter attivare in una zona più elettrovalvola contemporaneamente??
View: 1256   Answer: 1
Anne M
Updated at 2026-06-10 22:39:31 UTC
For test purposes, I have my Whisperer 2 in a terra cotta flowerpot that is very dry.  It always reads that the moisture is very high.  I have a Pixie at the house faucet.  I reset the Whisperer and it did not help.  What's wrong?
View: 1274   Answer: 1
Cannot connect to my WiFi
Updated at 2026-06-10 02:59:45 UTC
Tried several times following with the instructions. And failed!? And my system was operational and my App was disabled for no apparent reasons!?
View: 1289   Answer: 2
How do I save my password
Ruth Wengert
Updated at 2026-06-09 16:33:16 UTC
I doubt if someone’s gonna break in and change my sprinkler time how in the hell do I save my password to this thing? I don’t wanna have to remember to put it in every time I want to change my sprinklers.
View: 1534   Answer: 1
Massmo Tommasi
Updated at 2026-06-06 13:21:26 UTC
grazie
View: 1247   Answer: 1
Rain forecast
Riccardo!!
Updated at 2026-05-31 15:34:34 UTC
Hi, I have a Spark controller. Where can I find in the app the rainfall forecast for next days?
In the home page I can see only humidity, temperature and wind but not rain in mm.
Riccardo
View: 1428   Answer: 1
wunderground
Nino Guzzo
Updated at 2026-05-28 17:35:15 UTC
I can't register my weather station ID in the Netro app. Can anyone help me? Thanks.
sprite not using correct weather data
Douglas Peale
Updated at 2026-05-26 06:47:02 UTC
I have a home weather station that feeds data to https://www.wunderground.com/dashboard/pws/KCASANJO507?cm_ven=localwx_pwsdash
I have my sprite pointed at my specific weather station on wundergound.com. Today, my sprite claims I had 0.02" of rain, but my weather station detected none, and wunderground.com says I had no rain.
I have been noticing for a while that Netro was showing different rain data from what my weather station recorded, Netro usually records more rain than I actually got. I suspect this may be why my oranges are always under sized.
Somehow Netro is getting the wrong infromation from wunderground.com. Is there any way to fix this?
View: 1530   Answer: 1
Irrigation
Antonio Cordon Rodriguez
Updated at 2026-05-21 19:28:42 UTC
View: 2939   Answer: 2
Greenhouse zone
Ivan G
Updated at 2026-05-20 08:59:47 UTC
View: 2905   Answer: 1
