Will
Updated at 2026-03-17 21:54:57 UTC
View: 4354   Answer: 3
Seeding mode
John Sirois
Updated at 2026-03-15 04:23:37 UTC
View: 3617   Answer: 1
Monkeyzu
Updated at 2026-03-12 08:20:45 UTC
View: 3570   Answer: 1
New whisperer
Updated at 2026-03-03 08:20:29 UTC
Bought a new whisperer as an old one is no longer working.
REMARK : WHILE I LIVE IN A TEMPERATE AREA NONE OF MY WHISPERERS LASTS MORE THAN 26 MONTHS WHICH IS SURPRISING AS IT IS NOT SUPPOSED TO BE A CONSUMABLE.
Clicked as required first blinking blue light then blinking white light.
Went to sensors and see the dead old one, the working one but do not see the newly bought one.
Do not see either a + sign to add a new one.
What should I do ?
View: 3590   Answer: 1
RKR Home
Updated at 2026-03-03 03:32:35 UTC
View: 3636   Answer: 1
Support email- No reply
Updated at 2026-02-21 16:06:19 UTC
View: 3809   Answer: 2
Supported Hardware
Colin Brierley
Updated at 2026-02-12 06:13:48 UTC
View: 4018   Answer: 1
Feature Request
John Sirois
Updated at 2026-02-10 05:56:14 UTC
John
View: 3536   Answer: 1
Sensor to zone
Mark Zeck
Updated at 2026-02-05 23:17:03 UTC
How do I connect my sensors to zones? I have the latest.
View: 3723   Answer: 1
Notification
Alexis Demosthenous
Updated at 2026-02-05 19:28:19 UTC
View: 3702   Answer: 1
cpline
Updated at 2026-02-02 17:04:38 UTC
View: 3655   Answer: 1
Will
Updated at 2026-01-27 03:13:26 UTC
View: 3654   Answer: 1
Tuan Phan
Updated at 2026-01-25 18:28:34 UTC
View: 3491   Answer: 1
Old whisperer
Updated at 2026-01-20 10:38:33 UTC
Seems a communication problem
View: 3608   Answer: 1
Shane V
Updated at 2026-01-19 04:54:45 UTC
View: 3728   Answer: 1
Eric Jonsson
Updated at 2026-01-08 12:02:58 UTC
View: 3878   Answer: 1
The average temperature for a day is insufficient to calculate correct watering.
Richard
Updated at 2025-12-17 07:17:57 UTC
When I have Whisperers, the system appears to calculate the average over the day about 4 degrees higher than for zones without Whisperers.
It seems that, even though the weather data is available throughout the day, that zones without sensors only use the forecast high and low.
This is insufficient to correctly adjust for the amount of watering required.
For example, today is 7 degrees C up to 36.
Whisperer zones average the temp at 26C while non-Whisperer zone calculate the average at 22C.
On these extremely hot days, the non-whisperer zones are under-watering much more than the Whisperer zones.
Also note that even the zones with Whisperers always under-water and needs custom programs or manual intervention.
This finally explains to me why zones are always under-watered.
Can the system please use multiple day readings for non-Whisperer zones and PLEASE provide more watering?
View: 3904   Answer: 2
Watering on wrong day
keller3987
Updated at 2025-12-09 15:39:44 UTC
I have programmed my Netro to skip Tuesday’s but the controller waters anyway. How do I stop this?
View: 3891   Answer: 1
Cannot add pixie z1
John R
Updated at 2025-12-09 02:23:46 UTC
I cannot add my pixie z1 to the app because pixie z1 is not shown as an option. I have the hub connected.
View: 4052   Answer: 1
API broken?
Tortfeaser
Updated at 2025-11-21 04:58:13 UTC
Hi, I can get my Netro controller info using:
curl -v https://api.netrohome.com/npa/v2/info.json?key=MYAPIKEY
(where MYAPIKEY is a key from the user account page)
but when I try to update soil moisture data with:
curl -X POST -H "Accept: application/json" -H 'Content-Type:application/json' -d '{"key":"MYAPIKEY","moisture":100}' "https://api.netrohome.com/npa/v2/set_moisture.json"
I get an error about an invalid key:
{"status":"ERROR","meta":{"time":"2025-11-21T04:54:56","tid":"1763700896_KpmY","version":"2.0","token_limit":0,"token_remaining":0,"last_active":"2025-11-21T04:54:56","token_reset":"2025-11-22T00:00:00"},"errors":[{"code":1,"message":"Invalid key: ","params":{}}]}
What's going on?
View: 16258   Answer: 1
