Changing ownership
Andrew Hopkins
Updated at 2024-12-16 01:39:48 UTC
Andrew
View: 7820   Answer: 1
Changing ownership
Andrew Hopkins
Updated at 2024-12-16 01:38:57 UTC
Andrew
View: 7882   Answer: 1
Sprite / Spark and Flume
Bruce P
Updated at 2024-12-12 22:28:13 UTC
Thinking of scenarios like:
View: 7785   Answer: 1
Carolyn Simmons
Updated at 2024-12-01 20:53:00 UTC
View: 7931   Answer: 1
Andrea DS
Updated at 2024-11-27 21:01:38 UTC
Solenoid does not switch off
Nath Moyes
Updated at 2024-11-15 00:49:20 UTC
Nath
View: 8922   Answer: 1
Netro Spark valve testing
Peter Strohmayer
Updated at 2024-11-14 13:49:20 UTC
Peter
View: 8779   Answer: 1
Konrad
berlin
Updated at 2024-11-10 09:36:28 UTC
Who can help me?
Thank's
Konrad
View: 7628   Answer: 1
Zone won't shut off.
shoo.shoo
Updated at 2024-11-10 05:55:43 UTC
View: 8802   Answer: 1
Zine will not run
TJ Woods
Updated at 2024-10-27 14:40:45 UTC
View: 9383   Answer: 1
Conrtoler
John Zuzula
Updated at 2024-10-19 23:45:24 UTC
View: 7757   Answer: 1
BrettEnyart
Updated at 2024-10-13 18:02:06 UTC
View: 9143   Answer: 2
12330barryknoll
Updated at 2024-10-10 01:51:03 UTC
View: 9207   Answer: 1
Water restriction schedule problem
Carolyn Simmons
Updated at 2024-10-08 00:12:28 UTC
I cannot get the system to set up our county water restriction schedule. It is Wed and Saturday up to 10am in morning and after 6 pm at night. I would really like to run each zone once in the morning and once at night!  Any suggestions before I get fined $200.00?
View: 9909   Answer: 1
Set up weather underground
Giovannini Alex
Updated at 2024-10-05 18:35:32 UTC
Alex
View: 8241   Answer: 1
cjulian
Updated at 2024-10-05 18:05:09 UTC
View: 8976   Answer: 1
Manual mode without delay
Phil Houghton
Updated at 2024-10-04 23:27:59 UTC
View: 7612   Answer: 1
1 zone not watering
cowlo@xtra.co.nz
Updated at 2024-10-01 01:41:13 UTC
View: 9119   Answer: 1
How do I?
Rockhead413
Updated at 2024-10-01 00:08:51 UTC
Vincent Devlahovich
805-813-1216
Loyal customer
View: 7834   Answer: 1
Schedules
jonathansalina
Updated at 2024-09-28 11:11:52 UTC
View: 7965   Answer: 1
