one zone not opening
BBurford88
Updated at 2024-06-03 16:54:39 UTC
Has anyone had only one zone not work properly? I've checked my voltages and everything seems to be normal but one of my 4 zones does not operate either with the schedule or manually running the zone. Any tips help cause i'm at a complete loss.
Thanks in advance
Boyce
View: 7864   Answer: 1
Sensori funziona anomala
Mattia Forti
Updated at 2024-06-03 07:45:35 UTC
Ho un sensore che funziona male, non legge la temperatura e la lettura del umidità è un altalena.
Come posso risolvere? Inoltre rileva umidità 25% e sta piovendo abbondantemente da più di 2 ore.
View: 11107   Answer: 2
Rain skip only
Shawn C
Updated at 2024-06-02 21:09:04 UTC
How do I setup the Netro to only check for rain and skip the rainy days ?  I don’t want it to enable smart watering and change my watering schedule but I would like it to detect and skip rainy days.  Thanks!
View: 8249   Answer: 1
Mutiple Zone runing at the same time and half the zone (6-12) not actually running
harrywhl
Updated at 2024-06-01 23:57:27 UTC
My Netro-12 is currently running 5 zones at the same time when it was mannually turned on to go each zone at a time, also, the back end of the zones (6-12) does not respond to the app commands and whenever the app said the zones were turned on, it was still the first five zones that were running.
View: 8039   Answer: 1
Cant connect
B Ray
Updated at 2024-06-01 22:41:52 UTC
How close does this pixie z1 faucet timer have to be to the hub because it’s approximately 21 ft from it…
WiFi connected
Hub light is solid green
And the timer is offline
Won’t stay connected
View: 7922   Answer: 1
Pump shuts off after 5-10 mins
Vardhan Rajkumar
Updated at 2024-06-01 22:02:36 UTC
I just restarted my irrigation system after the winter.  I have tried to manually run a zone.  After watering for 5-10 mins the water turns off but the Netro timer still shows watering.
I am trying to determine whether the pump has turned off because the Netro "on" signal stopped or whether the thermal overload relay on the pump circuit caused it to shut off.
Is there a way I can check which it may be?
Vardhan
View: 8124   Answer: 1
Shut off one zone
Wil
Updated at 2024-05-31 04:05:40 UTC
View: 8201   Answer: 2
Two times zone watering
Jerry Agresti
Updated at 2024-05-30 17:03:18 UTC
Hi there. How can I program specific zones to water twice in one day?
View: 8049   Answer: 1
Invalid group ID 39654: invalid device status - shows in the app
Ashok Vengidapathy
Updated at 2024-05-28 05:22:36 UTC
I am getting an error in the app like " Invalid group ID 39654: invalid device status "
What would be the reason.  Also I am unbale to pair my device.
Please advise on this.
Ashok.
View: 8169   Answer: 1
Multiple zones running on Netro Sprite sprinkler system
gosparty01
Updated at 2024-05-27 17:47:14 UTC
I have three zones that are running at the same time with low water pressure to all three. This is a new problem. Any ideas on hat might be causing it?
So far I've tried replacing one solenoid, that did not work. I switched the zones in the control box for one of the three zones but the same result when I activated the switched zone.
I also tried disconnecting one of the zones, and when I triggered it it did not run. But when I triggered one of the zones I left connected, it did run with low water pressure
View: 7979   Answer: 1
Moving from hunter to netro 12 zones
rabatmaroc
Updated at 2024-05-27 02:50:28 UTC
Hi gents
I have setup a new up to 12 zones metro  replacing an 8 zone hunter system.
So far only 5 zones are active
I am missing something small
Hunter old wiring attached
View: 8557   Answer: 2
WATER SCHEDULING / WEATHER INFORMATION UPDATE
Javier NM
Updated at 2024-05-26 06:49:27 UTC
First of all, I have been using my Sprite for one year, and the result is very positive. My lawn is better, and I have learnt about how watering should be done in my case. Congratulations to the Netro team. Let me add some questions below.
On 2023-06-13 Wency said "Netro sever side gets/ updates weather information every early morning at around 4 am.
If the weather forecast changes, Netro will update and recalculate the schedule." But could you expand what time zone is this 4 am?.
And a second question is: how often the system recalculates the watering scheduling after a programmed or manual watering? Will that go in the same refreshing as the weather info refreshing? also at 4 am?
View: 8414   Answer: 1
Javier NM
Updated at 2024-05-26 06:32:56 UTC
View: 8491   Answer: 1
Zone Won't Disable
Updated at 2024-05-25 20:49:25 UTC
I have tried to disable this zone in settings, but it will not disable.  If anyone knows a solutions please let me know.
View: 8208   Answer: 1
No Answers
Charles Currie
Updated at 2024-05-25 17:07:13 UTC
View: 8098   Answer: 1
mae winslow
Updated at 2024-05-24 02:05:23 UTC
View: 8014   Answer: 1
2 separate systems
Roger Johnston
Updated at 2024-05-22 19:07:12 UTC
We have a 9 zone lawn system and a seperate 4 zone garden system. The controllers are 100 yards apart. We hand 2 Netro controllers and a home network that covers the entire area. Can both controllers be operated with one same app? I’ve tried but without success….must be missing something.
View: 7972   Answer: 1
Weather Underground
LM90
Updated at 2024-05-22 16:23:22 UTC
Hi. The app wont let me add my wundergound id number (IRIBBE4). Can you please help
View: 8078   Answer: 1
Whisper 2 problems
Phil Middleton
Updated at 2024-05-20 09:13:29 UTC
View: 8400   Answer: 1
Compatibilità con Smartthings
Farina Vincenzo
Updated at 2024-05-18 20:44:01 UTC
View: 8074   Answer: 1
