Pixie Offline
mprtjd
Updated at 2025-05-03 15:33:15 UTC
View: 7232   Answer: 1
Batteria pixie
Max64
Updated at 2025-05-02 08:32:19 UTC
View: 7305   Answer: 1
Soil and weather
Stephen Brewer
Updated at 2025-04-29 10:06:27 UTC
Steve
View: 8994   Answer: 1
IFTTT Trigger for moisture
Kareo
Updated at 2025-04-29 04:50:52 UTC
View: 7531   Answer: 2
does not irrigate
Giovanni Asoni
Updated at 2025-04-28 15:58:30 UTC
View: 7447   Answer: 1
Irrigation system service
Rick Joseph
Updated at 2025-04-27 19:53:45 UTC
View: 7148   Answer: 0
Server Down 4/27/25?
Updated at 2025-04-27 19:38:18 UTC
View: 7603   Answer: 5
Whisperer 2
Stephen Brewer
Updated at 2025-04-24 13:43:01 UTC
Steve
View: 8436   Answer: 1
Garden Bib
Grant Sullivan
Updated at 2025-04-22 22:01:02 UTC
View: 9019   Answer: 1
Andrea DS
Updated at 2025-04-22 12:33:21 UTC
View: 8017   Answer: 1
24 hrs
Eric Jonsson
Updated at 2025-04-19 08:19:24 UTC
View: 8063   Answer: 1
Google Home Assistant
Eric Jonsson
Updated at 2025-04-19 07:46:16 UTC
Eric
View: 7909   Answer: 1
sdt_babel
Updated at 2025-04-08 17:57:42 UTC
View: 8149   Answer: 1
Matt
Updated at 2025-04-08 16:25:11 UTC
View: 7862   Answer: 1
Robert Greenwood
Updated at 2025-04-06 18:47:24 UTC
View: 7535   Answer: 1
New Whispere
Updated at 2025-03-31 21:05:02 UTC
What should I do ?
View: 7977   Answer: 1
Netro Whisperer gen2 4 zones
Luca Gennuso
Updated at 2025-03-25 22:22:40 UTC
View: 7932   Answer: 1
Dutch language improvement
Perry en Louise Mevissen
Updated at 2025-03-22 08:54:24 UTC
Kind regards,
Perry
View: 8089   Answer: 1
Greenhouse
Updated at 2025-03-22 08:43:22 UTC
One of our sectors runs inside a greenhouse now. Apart from soil type and sprinkler head type, does anyone have advice how to optimise sector settings for this situation? I feel the influence of sun and normal outdoor temperature is different, and rain is completely absent in this sector.
May I suggest to add some sector setting that it is inside a greenhouse?
Perry
View: 9013   Answer: 1
Whisperer availability
Updated at 2025-03-16 18:50:01 UTC
View: 9300   Comment: 1
