Instructions about Replacing Rainbird System
Updated at 2019-03-20 08:06:44 UTC
Replacing Rainbird system
This page lists some instructions about replacing the common types of Rainbird system with Netro smart watering controller.
Example 1:
 The common wires which should be connected to the C slots in Netro.
The Sprite controller does not need the ground wires. It does not need the rain sensor either. You can leave the M slot unconnected.
Example 2:
The COM wire goes to any C slot in Sprite.
The M slot will be empty because you do not have master valve.
The two red wires on the left go to the two 24 VAC slots.
Others are straightforward.
Example 3:
1. the COM wire in RainBird go to any of the C slots in Netro
2. The 1-6 zone wires in RainBird go to Slot 1-6 in Netro
3. Use the power adapter coming with the package for Netro
Other wires you can disregard them.
Example 4:
12(blue) and 11(red) go to the two AC slots on the right side for Netro. 10(white) goes to any one of the C slot in Netro. 9(black) goes to the M slot in Netro. 8-1(red) go the ZONES in Netro. You can leave the green wire (GND) open. The two leads from the power adaptor go to the two AC slots.
View: 13117   Comment: 0
Updated at 2019-03-20 08:03:05 UTC
Replacing old system
Example 1:
I check the pictures.
OLD                 Sprite
COM                any C slot
1                     1
2                     2
3                     3
4                     4
Example 2:
Example 3:
Example 4:
Other wires are not needed.
Example 5:
View: 7679   Answer: 0
Updated at 2019-03-19 04:52:48 UTC
View: 9325   Comment: 0
Overriding smart waterinh
mvernia
Updated at 2019-03-17 20:46:27 UTC
View: 6662   Answer: 1
Scot and Michelle Cowan
Updated at 2019-03-03 17:04:51 UTC
View: 7785   Answer: 1
Nathan Anderson
Updated at 2019-02-13 03:53:31 UTC
View: 7132   Answer: 1
Tim Cox
Updated at 2019-02-02 01:35:59 UTC
View: 7124   Answer: 3
St. Augustine
Spencer Vaughn
Updated at 2019-01-10 03:15:53 UTC
View: 8834   Answer: 2
Leak detection
Joshua Berk
Updated at 2019-01-03 15:27:07 UTC
Rachio has a new leak detection device you can install on the pipe that talks to the controller letting it know if there's water flow that shouldn't be happening. Do you guys have plans to do anything like this? Would absolutely be interested in it!
View: 6955   Answer: 0
Sangjin Lee
Updated at 2018-12-15 18:56:48 UTC
Thanks in advance!
View: 10704   Answer: 1
Updated at 2018-12-13 07:48:53 UTC
Burning Bush
Fragrant Sumac
Japanese Yew
California Lilac
Creeping Juniper
Dwarf Forsythia
Snowberry
Siberian
Carpet Cypress
View: 10630   Comment: 1
Rebekah H
Updated at 2018-11-28 04:23:43 UTC
View: 7023   Answer: 1
Water pump shutting off
Ryan Cochran
Updated at 2018-11-26 02:32:24 UTC
View: 7068   Answer: 1
EPA rebate status?
Joshua Berk
Updated at 2018-11-04 07:39:58 UTC
Hi I was wondering if we could get an update on where Netro is with an EPA rebate? We're aware Netro has applied, but any word or ETA on getting certification for rebates?  Thank you
View: 7605   Answer: 3
Skipping skipped?
livingwater71
Updated at 2018-10-31 16:11:03 UTC
View: 6716   Answer: 1
Service
Matt Lasser
Updated at 2018-10-31 16:01:30 UTC
View: 7044   Answer: 1
George Zraick
Updated at 2018-10-27 20:05:15 UTC
View: 6971   Answer: 1
Moberley
moberleyj@verizon.net
Updated at 2018-10-17 16:59:29 UTC
View: 7015   Answer: 1
connecting to wifi..
Phani Gade
Updated at 2018-10-15 17:20:42 UTC
View: 6551   Answer: 0
Customization->set rain/temperature/wind threshold to skip watering
Updated at 2018-10-13 06:19:08 UTC
Netro automatically creates dynamic watering schedules according to local weather, so if you turn on the smart zone feature for your zone, season adjustment will be made with smart watering schedules according to weather.
There are different types of weather restrictions: rain, temperature and wind.
By default, If you turn on the smart zone feature, Netro will skip the schedules (including manual schedules from user programs) when there is a chance of significant rain(>0.2inch).
The default threshold to skip watering when temperature is too low is 0 Celsius degree (32 Fahrenheit) for all the Netro controllers.
You can now customize rain, temperature and wind threshold through Settings->Preferences.
View: 9447   Comment: 0
