Don’t Stop !!
Eduardo Ariste
Updated at 2019-05-26 11:27:42 UTC
View: 6465   Answer: 1
Netro off line
Updated at 2019-05-25 02:59:21 UTC
View: 7105   Answer: 1
Joshua Berk
Updated at 2019-05-23 18:39:21 UTC
View: 6991   Answer: 1
Can't see answers to questions
Stan Bumgarner
Updated at 2019-05-23 00:30:01 UTC
I can see the question and can see that someone has answered it. How do I see the answer?
Stan
View: 6555   Answer: 1
Remote Access?
Oliver Pettit
Updated at 2019-05-22 01:53:35 UTC
Oliver
View: 7002   Answer: 1
Manually skip next watering
Randy Ziffer
Updated at 2019-05-19 16:47:13 UTC
View: 6763   Answer: 2
jpmeyer81
Updated at 2019-05-19 15:04:11 UTC
View: 6879   Answer: 1
Roianne Cox
Updated at 2019-05-19 13:52:50 UTC
View: 6454   Answer: 1
Dennis N
Updated at 2019-05-18 17:52:30 UTC
View: 6516   Answer: 1
David Claridge
Updated at 2019-05-18 13:21:53 UTC
View: 6553   Answer: 1
Steven V
Updated at 2019-05-18 13:08:55 UTC
View: 6574   Answer: 1
Hot weather algorithm
Joshua Berk
Updated at 2019-05-17 16:15:51 UTC
View: 7142   Answer: 2
Whisperer stopped working
Pelle Fisk
Updated at 2019-05-17 13:30:13 UTC
View: 7689   Answer: 2
Manual mode fail to shut off
Updated at 2019-05-16 02:05:13 UTC
View: 7054   Answer: 1
Updated at 2019-05-14 07:01:36 UTC
View: 7628   Answer: 2
Problemi con Google home
Max Point
Updated at 2019-05-12 08:36:40 UTC
Massimo
View: 6723   Answer: 1
is the Pixie faucet joint (both in and out) GHT (Garden Hose Thread) or NPT (National Pipe Thread)
Oliver Pettit
Updated at 2019-05-09 01:33:23 UTC
Could you please confirm if the Pixie faucet joint is GHT (garden hose thread) or is it NPT (National Pipe Thread)?
I'm looking for adapters in Australia to use this unit and its unclear what the size/type the faucet is.
View: 7170   Answer: 1
Henry
Updated at 2019-05-06 19:40:59 UTC
same issue...
so what to do with it?
View: 6901   Answer: 2
John Locke
Updated at 2019-05-05 14:16:12 UTC
View: 6921   Answer: 1
Graphs
Jim Bethea
Updated at 2019-05-04 11:25:22 UTC
View: 6588   Answer: 1
