Sangjin Lee
Updated at 2019-10-17 03:41:11 UTC
View: 7583   Answer: 1
Brian Hobbs
Updated at 2019-10-15 01:58:49 UTC
View: 8801   Answer: 1
Weird watering plan
Manuel Roca
Updated at 2019-10-12 11:34:00 UTC
View: 7311   Answer: 1
Installation Direct to pump
Tim Foster
Updated at 2019-10-03 11:23:32 UTC
I have the following:
View: 9386   Answer: 2
sqwu
Updated at 2019-09-30 13:51:09 UTC
View: 7727   Answer: 1
Nguyễn Vinh
Updated at 2019-09-30 06:46:55 UTC
View: 9266   Answer: 2
hanz.blatt@gmail.com
Updated at 2019-09-29 13:59:02 UTC
View: 13591   Answer: 2
Cold winter season and whisperer ?
Yves Desrosiers
Updated at 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
View: 10702   Answer: 3
Solid white light after install - HELP
Carlos Oliveira
Updated at 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
View: 9071   Answer: 1
Ip address
Kris Y
Updated at 2019-09-25 20:13:08 UTC
View: 7552   Answer: 1
Tony D.
Updated at 2019-09-24 21:08:17 UTC
Hello everybody,
View: 7822   Answer: 1
Whisperer seems wrong
Tim Foster
Updated at 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
View: 8871   Answer: 1
Schedule setup
Rich Christenson
Updated at 2019-09-21 14:51:31 UTC
View: 7386   Answer: 1
Unit measurements
Homestead One
Updated at 2019-09-17 20:29:09 UTC
View: 7326   Answer: 1
Updated at 2019-09-17 12:12:15 UTC
View: 9270   Answer: 1
Feature request
Tony D.
Updated at 2019-09-12 20:32:30 UTC
Tony
View: 7868   Answer: 1
Tony D.
Updated at 2019-09-09 12:57:04 UTC
View: 8282   Answer: 1
Windows 10 APP or web page
Emanuel Di Giusto
Updated at 2019-09-06 19:46:57 UTC
View: 7354   Answer: 1
Manual run time screen
Rich Christenson
Updated at 2019-09-06 10:25:49 UTC
View: 7788   Answer: 1
New Whisper not reporting
Updated at 2019-09-04 17:11:14 UTC
I recently ordered a second whisper and installed it the same way as the first one I received (which is still working fine)  It connects just fine and I can even change the color of the LED for a while.  But it reported only once to the app and that was it.  I have tried reconnecting it to WiFi, I even deleted it in the app and reinstalled it with no success.  After the initial connection it seems to just stop working.
View: 9435   Answer: 1
