Jonathan B.
Updated at 2019-06-24 03:20:54 UTC
View: 7287   Answer: 2
Updated at 2019-06-23 13:34:06 UTC
View: 6149   Answer: 1
watering usage doesn't match
Sangjin Lee
Updated at 2019-06-21 22:49:22 UTC
Here is something I cannot reconcile. I am dealing with a pretty big water usage reported by the utility. It says in the month of May I used 530 GPD (gallons per day). I seem to be watering every 3 days (set by Netro).
Compared to winter months when I rarely watered the lawn due to the rainy season, it is a jump of ~ 270 GPD.
When I check the Netro app, it reports I used ~ 3.5 CCF for the month of May. 1 CCF = 748 gallons, and that translates to roughly 87 gallons per day. This is less than 1/3 of what the utility is telling me. How can this discrepancy be explained? Any ideas/tips for finding why I seem to be using this much water? Thanks in advance!
View: 6981   Answer: 1
Start / End time
Updated at 2019-06-21 10:14:14 UTC
View: 6726   Answer: 1
GPS position
alesee COA
Updated at 2019-06-21 08:24:13 UTC
View: 5371   Answer: 1
Not enough water
Robert Arnold
Updated at 2019-06-19 03:22:58 UTC
View: 6410   Answer: 1
Amount of Rainfall keeps changing
Swaroop Jay
Updated at 2019-06-19 02:47:10 UTC
Netro app keeps changing the amount of rainfall that we have had. Day before yesterday it rained heavily. The very next day Netro app showed that it rained 1 inch. Today it’s showing that on that same day it rained only 0.33 inch. Any idea why it keeps fluctuating for something that has already happened in the past?
View: 5465   Answer: 1
Simon Sollberger
Updated at 2019-06-18 20:39:36 UTC
View: 7740   Answer: 2
Simon Sollberger
Updated at 2019-06-18 14:27:43 UTC
View: 6879   Answer: 0
Plant sensor readings
Dan Orms
Updated at 2019-06-18 03:16:48 UTC
View: 5736   Answer: 1
Difficulty connecting to Google WiFi
Chris Miller
Updated at 2019-06-18 02:12:25 UTC
I have a Sprite that refuses to connect to my Google WiFi.  Even with the router in the garage with it.
It will connect to a mobile hotspot on a cell phone.  Is there a known issue for Google WiFi?  I have tried all of the troubleshooting steps without any luck.
View: 7386   Answer: 2
Netro's Rain Delay Feature
Updated at 2019-06-18 01:41:04 UTC
View: 8242   Answer: 0
Cam
Updated at 2019-06-16 01:05:25 UTC
View: 6173   Answer: 1
Configuration for Netro Sprite suggestions requests
Tony D.
Updated at 2019-06-14 22:30:14 UTC
I am interested in buying the Netro Sprite sprinkler. I read several reviews and they are all pretty good. I noticed that many state that the sprite is not able to water two zones at the same time. Is this something limited by project and wanted or do you think it could be upgraded with a software upgrade?
I wanted to ask you some questions about my garden layout. I attach a planimetry for convenience.
The garden consists of two pieces surrounded by railings with a central railing too. The one on the left side is about 70cm lower then the one on the right side.
The two big areas are covered with lawn. At the left side border there are 8 laurus nobilis plants (https://en.wikipedia.org/wiki/Laurus_nobilis) while at the right side border there are 8 Trachelospermum jasminoides plants (https://en.wikipedia.org/wiki/Trachelospermum_jasminoides).
Based on your experience how many zones would you create. At first I thought to go with three zones: one for both lawn plots, one for the laurus and another for the Trachelospermum. My doubt is I need to split the two lawn plots into two separate zones. How would the inability to operate different zones at the same time affect the watering and would the Sprite handle different times automatically or would I need to intervene manually?
My last question is about the Whisperer sensor, how many of them would you place in the garden?
Waiting forward to your suggestions,
Tony
View: 7553   Answer: 1
Zones Scheduled; Did Not Run
Matt O.
Updated at 2019-06-14 14:30:18 UTC
Good Day,
View: 6916   Answer: 1
morriewayne17@yahoo.com
Morrie Wayne
Updated at 2019-06-14 13:27:19 UTC
View: 8518   Answer: 0
Updated at 2019-06-14 11:23:21 UTC
View: 5874   Answer: 1
Rain Delay
Peter Parker
Updated at 2019-06-14 06:50:18 UTC
Thoughts?
View: 5857   Answer: 2
Notification
Christophe Delanoy
Updated at 2019-06-14 06:44:13 UTC
Hello ,
- starting watering
- watering report
That would be useful
-Christophe Delanoy
View: 5685   Answer: 1
Dan Orms
Updated at 2019-06-13 18:06:42 UTC
View: 7068   Answer: 1
