Days not appearing on 6-days a week schedule
Rec Tift
Actualizado 2023-05-17 02:40:49 UTC
Our watering restrictions are on 6-days a week. Thursday, Friday, and Saturday do not show water schedule. How do I add these days to program?
Ver: 8088   Respuesta: 1
Richard Nibbler
Actualizado 2023-05-17 02:50:09 UTC
Tyvm
Ver: 8546   Respuesta: 3
Problem in Netro app in my iPhone
Manel Barbero
Actualizado 2023-05-18 08:21:17 UTC
I had installed an irrigation controller and one plant sensor and it worked OK. Since I have added one Pixie-1 and one Pixie-Z1, on the app screen when I try to enter innthe red ring bell to see notifications, I am thrown out the app and I can’t see my notifications.
Ver: 8414   Respuesta: 1
Watering problem
Marco Nicosia
Actualizado 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
Ver: 7795   Respuesta: 1
App Showing Ofline
Katie Wallace
Actualizado 2023-05-21 11:09:21 UTC
Ver: 7670   Respuesta: 1
Mismatch zones/times
Jose R
Actualizado 2023-05-21 12:40:53 UTC
So happy with how this works.
Ver: 7817   Respuesta: 1
Strange watering cycle
Joe Mariano
Actualizado 2023-05-22 14:40:16 UTC
Ver: 8152   Respuesta: 1
Material
Georges Bouvier
Actualizado 2023-05-23 07:32:12 UTC
Does Netro supply an equipment with 2 output
I need watering 2 different areas?
Thks
Ver: 10371   Respuesta: 2
Cannot connect
Jerry Gadd
Actualizado 2023-05-23 19:15:35 UTC
I am not able to successfully connect to my new pixie
1. Pixie lifht flashing white
2. Login to App
3. Add Product
4. Select device
5. Enter name and addess info
6. Begin
7. Connext phone to Netro wifi
8. Next
9. Select homw wifi
10. Enter password
11 next
... Connecting...
Pixie light flashes white, eventually turns red
App errors
Wifi password is correct, and i am in same room as router aand pixie is next to me.
How dobi check port is not beinf blocked hy router? I have Huaweu Q2 Pro, dont see anything tonsuggest iit is.
Ver: 10853   Respuesta: 1
Frequently disconnection from the wifi
PaoloMassignan
Actualizado 2023-05-24 05:07:48 UTC
My device is always offline unable to connect to the wifi. I have to reset it and then the connection works for a while.
There is a repeater  2 meters from it. The signal is strong.
Ver: 7927   Respuesta: 1
Update the irrigation routine according to the updated weather forecast
Luis T
Actualizado 2023-05-24 15:44:31 UTC
Hi there!
I live in Madrid, Spain and use AccuWeather as my weather provider, since NetroWeather does not provide a correct forecast for this area for some reason.
This week we have had heavy rain forecast so Netro will not activate the irrigation system for several days. The problem is that as the day goes by the forecast is changing and Netro's planning is not updated.
It has already been several days in which according to the initial forecast, it was supposed to rain and it did not, so I have had to launch manual irrigations.
Is there any way to force the smart irrigation program to update according to the new weather forecast?
Ver: 8806   Respuesta: 1
Netro Spark firmware version
Luis T
Actualizado 2023-05-24 15:54:35 UTC
I have a Netro Spark with firmware version 3.2.1. Firmware updates are done without user intervention or how can I perform a firmware update?
Ver: 8708   Respuesta: 1
A Netro Spark with no WIFI
Lino
Actualizado 2023-05-25 16:07:02 UTC
Just bought a Spark and realized my home wifi sig doesn’t reach the location where it is installed.
While I sort out how to increase the signal I wonder if there is a way to program the Spark to operate without Wifi
Ver: 8060   Respuesta: 1
Rotor head
Sjors Janssen
Actualizado 2023-05-25 19:15:07 UTC
I've just been using a Netro Spark to water my garden. I have set up 3 zones. Two of these zones have a rotor head sprinkler. However, they don't cover the same area. One of them rotates over 90 degrees. The other rotates 180 degrees. So I think the rotor head that covers the 180 degrees needs to run double the time of the 90 degree one. How can I set this? I've set the sqm for each head, but smart irrigation used the same times for both.
Kind regards,
Sjors
Ver: 7899   Respuesta: 1
Zones
Lea Schneider
Actualizado 2023-05-25 23:29:01 UTC
My zones 5-12 won’t work but my zones 1-4 are working fine .    Any ideas what to do ?
Ver: 8037   Respuesta: 1
Manuel Run delay
BOBBY BROWNE
Actualizado 2023-05-26 00:37:50 UTC
Why is it when I hit manual run? There’s always a delay.
Ver: 8001   Respuesta: 1
Can I back up my Netro?
Jacob Matheny
Actualizado 2023-05-26 15:39:51 UTC
Ver: 8191   Respuesta: 0
Jacob Matheny
Actualizado 2023-05-26 15:39:56 UTC
Ver: 8329   Respuesta: 1
Unable to delete 6-zone control unit from PC
Luciani Daniele
Actualizado 2023-05-27 09:26:29 UTC
This morning I had to reset the 6 zone control unit. After the reset everything is fine from the Netro app. Instead, when I log in from a PC with my account, the old setting is detected and it won't let me delete it. The system returns error nvalid group ID 33131: invalid device status.
What to do?
Ver: 8450   Respuesta: 1
One channel is always on
Stefan W.
Actualizado 2023-05-27 19:58:05 UTC
Hi everyone,
I have a 6-channel Sprite with 6 hunter valves. 5 channels work perfectly, one seems to be always on. I tried a brand new valve, a reset of the Sprite, unplugged it from power, changed the wiring but nothing helped. Any ideas?
Cheers, Stefan
Ver: 8185   Respuesta: 3
