Hub with more than 1 timers
Kay Fluhr
Actualizado 2023-10-08 07:46:18 UTC
Dear netro team
I solved the problem.
Ver: 8222   Respuesta: 1
Zone failure to run
Homestead One
Actualizado 2023-10-09 08:30:37 UTC
Hi, I have one out of 4 zones who won't start watering. I have changed the valve and the problem still persist. I have checked the connections and the cables, all looks good. There is voltage.
Any ideea?
Ver: 7489   Respuesta: 1
Whisperer maintenance
Fabrice GOUFFRAN
Actualizado 2023-10-11 02:34:36 UTC
Ver: 6939   Respuesta: 1
Sprite 12 Controller Problem
John LaRocca
Actualizado 2023-10-14 01:42:23 UTC
Ver: 8068   Respuesta: 1
Terrible product?
Andrew Martin
Actualizado 2023-10-16 14:26:31 UTC
Three hours to setup
Ver: 8437   Respuesta: 2
