Maximum watering duration for SPARK
Katarzyna Wrobel
Actualizado 2023-04-11 22:55:50 UTC
Hi there :)
I want to set-up a watering duration for my desert garden (Phoenix, AZ). We should water our garden deeply and infrequently. So, I want to set-up a watering time of two hours. Unfortunately, the app has a maximum duration set to 60 minutes only. Any suggestions?
Ver: 7753   Respuesta: 1
Whisper will not factory reset!
Ross Brown
Actualizado 2023-04-13 10:43:03 UTC
Hi I have had to send back my spark due to a problem with one zone not operating, I’m now trying to do a reset on my whisper, I have pressed the power button quickly 6 times, on numerous occasions and cannot get it to reset, any help would be much appreciated. New Spark arrived and working well, l just can’t seem to reset the Whisper no matter how many times I try the on/off 3 times. Are there any other action I could do or do I return it for a replacement?
Ver: 10138   Respuesta: 1
Suggestions and Question.
Maurizio Gianesin
Actualizado 2023-04-12 15:08:32 UTC
Good morning.
I just started using Netro Sprite 8 zones out of 12 zones with two whisperers.
Congratulations for the App and the Web interface I'm using.
I have a concern about some trivial errors in the interfaces:
If you go to settings/preferences/SchedulingSetting
1.1 The Italian translation of "Two Frames" in "Due Cornici" makes me smile, it is better translated in "Due Cicli" or "Due Fasi". But my suggestion is also for English : it is my opinion that if instead of "Time Frames" and "Two Frames" you use "Time Phase" and "Two Phase" it is much better also for English and automatic translations free from misunderstandings.
1.2 Only in the App and not on the Web, the description of the two phases has "afternoon" under "morning" and vice versa.
Now I have a question:
I ask you for an explanation on Smart Scheduling.
I had set a lower limit of 10 C° and a Time Phase of 6:00 - 10:00. When I removed the 10 C° limit, the system did the same day a cycle at 23:58 instead of waiting for 6:00. why?
I hope I have been helpful and thank you for any response.
Ver: 7962   Respuesta: 1
Wasteful
David Maerzke
Actualizado 2023-04-13 13:19:47 UTC
Ver: 7877   Respuesta: 1
carlos davalos melgar
Actualizado 2023-04-13 20:06:46 UTC
Ver: 8209   Respuesta: 0
Actualizado 2023-04-13 20:06:57 UTC
Ver: 10728   Respuesta: 0
Actualizado 2023-04-13 20:07:05 UTC
Ver: 10504   Respuesta: 1
Matt Ward
Actualizado 2023-04-14 13:57:11 UTC
Matt
Ver: 8562   Respuesta: 3
Intelligent mode useless
Juan Lambea
Actualizado 2023-04-14 15:51:37 UTC
Ver: 11089   Respuesta: 1
dummy serial for testing
Actualizado 2023-04-16 17:53:00 UTC
Ver: 8472   Respuesta: 1
Multiple users
Norm Markworth
Actualizado 2023-04-17 00:22:59 UTC
Norm
Ver: 9043   Respuesta: 2
Pixie keeps disconnecting
Sang Peiris
Actualizado 2023-04-18 12:44:42 UTC
Ver: 8140   Respuesta: 1
Add user Error
Actualizado 2023-04-21 09:26:43 UTC
Ver: 7758   Respuesta: 2
farenheit to celsius
Santiago Moller
Actualizado 2023-04-22 02:41:55 UTC
Hello, I need help to change the settings from Fahrenheit to Celsius in the app, I have a smart plant sensor.  Thank you
Ver: 8728   Respuesta: 1
Area
Javier Domínguez
Actualizado 2023-04-22 16:04:10 UTC
Hola,
Cuando estoy configurando las zonas me pide un valor de area, ¿en qué medida? ¿Metros cuadrados?
Ver: 8201   Respuesta: 1
valves under relay
Alek
Actualizado 2023-04-22 17:48:29 UTC
Ver: 10353   Respuesta: 1
Master error “open circuit”
Neil Lucey
Actualizado 2023-04-24 14:09:12 UTC
Neil
Ver: 7946   Respuesta: 1
Actualizado 2023-04-24 14:27:08 UTC
Sprite / app
Never before
Disconnection to wifi
Even when say : online
irrigation )
Ver: 8517   Respuesta: 1
Jim
Actualizado 2023-04-24 17:38:25 UTC
Ver: 8298   Respuesta: 2
Katie Woggins
Actualizado 2023-04-24 18:40:07 UTC
Ver: 7832   Respuesta: 1
