Interface language
Bayoule Bayoule
Actualizado 2022-05-11 19:31:03 UTC
Bayoule
Ver: 6661   Respuesta: 1
Actualizado 2022-05-11 19:37:04 UTC
Ver: 6989   Respuesta: 1
Netro not connecting
hawkshah
Actualizado 2022-05-12 02:02:39 UTC
I have switched internet providers and now Netro won’t connect to att modem.  I have run through setup many times
Ver: 6209   Respuesta: 1
stelio
Actualizado 2022-05-13 00:33:14 UTC
Netro working fine last summer , I can seem
To get it to stay online . I reset the Netro and it work fine for the first 10 min … then it logs off and leave on zone open . I don’t know what to do ,To keep it online ?
Ver: 6716   Respuesta: 1
Invalid station id WU
Richard B
Actualizado 2022-05-13 00:47:24 UTC
Ver: 6485   Respuesta: 1
Invalid station WU
Bayoule Bayoule
Actualizado 2022-05-13 03:51:52 UTC
JM
How do I set on/off times?
Rikki Swin
Actualizado 2022-05-13 17:37:43 UTC
How do I program the on/off time on the new software? I need to have gaps between zones for pressure to rebuild. The new software is not intuitive!!!
Ver: 6213   Respuesta: 1
Manual Run
Dick Goddard
Actualizado 2022-05-13 20:53:29 UTC
Please help
Ver: 6899   Respuesta: 2
Good evening It but impossible to connect me netro tells me to make sure that the correct WIFI password is entered ... I have been trying to appear for 4 hours
GERMONT Alain
Actualizado 2022-05-13 23:02:49 UTC
Good evening
Ver: 7007   Respuesta: 3
Programación
jmgrau
Actualizado 2022-05-15 05:30:10 UTC
Buenos dias, como tengo que programar para que la schedule no actúe solamente funcionen los programas que yo programe.
Si programo algún programa, ahora me sale la schedule también.
Ver: 8323   Respuesta: 1
Offline since a couple of days
Daniel Torres
Actualizado 2022-05-15 10:01:39 UTC
Since a couple of days my Netro is offline. I have connected to my Netro to add the wifi password again and rebooted the router 3 times but still offline.
Ver: 6665   Respuesta: 1
Sprinklers only turn for a few second
Gabriele Wiel
Actualizado 2022-05-15 11:11:42 UTC
good morning
just installed his transformer burned out I had an electrician install a new transformer, now it works but the sprinklers only turn on for a few seconds, what can it be
This is a photo new transformer
Ver: 8397   Respuesta: 2
Weather .
Gianluca De Virgilio
Actualizado 2022-05-15 17:39:09 UTC
Good afternoon. The Weather forecast avvailable are absolutelly not real. What can I do?
Could you help me to con figure weather underground?
Ver: 6921   Respuesta: 2
Fabrice GOUFFRAN
Actualizado 2022-05-16 18:02:23 UTC
Good morning, Italy is my home, I recently started to use Netro replacing an old watering device I have used for several years, so far happy with my choice. I have one whisperer sensor device and I need 2 more but they are sold out on your online website, Amazon italy is also sold out with no forecast on new availability, where can I buy ?. Thank you.
Ver: 8949   Respuesta: 2
Restrictions do not include minute limits
Cheryl Michael
Actualizado 2022-05-17 03:03:27 UTC
I cannot find a way to reduce the minutes each station is watered. All stations on Eco boost. And some water almost an hour total (in 3 sessions) on allowed watering days. Our local So Cal restrictions are 10 minutes per station! How do I restrict  this?
Ver: 6364   Respuesta: 1
Bruno
Actualizado 2022-05-17 19:49:58 UTC
Ver: 7120   Respuesta: 1
Home Tab
bdcfam
Actualizado 2022-05-18 04:36:33 UTC
Ver: 6845   Respuesta: 1
Text in gray
Ignacio Sánchez
Actualizado 2022-05-18 11:26:32 UTC
Ver: 6821   Respuesta: 1
Pixie automatic water
Shirley Johnson
Actualizado 2022-05-18 18:20:36 UTC
My pixie won’t find my Wi-Fi. I’ve rebooted my router but didn’t help.
Ver: 8352   Respuesta: 1
Emilio
Actualizado 2022-05-20 17:05:31 UTC
Buenas tardes,
Pronóstico o expectativas.
Ver: 6450   Respuesta: 1
